What kind of torx tool needed for E36 tranny bellhousing?
  • rosphill
    • Jun 2007
    • 187
    I need to separate my Getrag 250 from the M50 engine.
    Can someone show me a link to the type of Torx sockets/bits needed for this?
    It looks like I need M6, M8, M10, M12 sizes.
    Is it the inverted Torx that I need?
    I can't find anything that looks right that has the range of sizes.
    Thx
    Originally Posted by Blunt
    I've done this so much I have a toenail on my dick.
  • matt
    • 3732
    It's inverted torx. The $20 one from Sears is fine.
    • rosphill
      • Jun 2007
      • 187
      Ok,
      That's the one I shall get then.
      Thanks much for the info!
      • erik325i
        • Jan 2005
        • 3567
        The sizes you need are E10, E12, and E14.
        • e30s50dan
          • Nov 2008
          • 2076
          they have them at Autozone too cheaper!!
          NASA
          BMWCCA member
          PCA member 25yrs
          1991 318IS slick top
          1997 M3 sedan
          2001 325CI DD
          “whoever turns the wheel the least, wins"
          • sharky
            • Jan 2005
            • 2672
            Yep got mine at vatozone, not super cheap but cheaper than sears. How many times are you going to seperate this part anyhow? plus stripping the heads are very difficult so a cheaper piece is just fine for this situation.
            • RoadHazard
              • Sep 2007
              • 163
              http://www.pelicanparts.com/catalog/...CAT040_pg2.htm
              90 E30 S50B30
              http://www.fquick.com/roadhazard/
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                If you want to be a cheap ass, you can get a whole set of them for 8 bucks at Harbor Freight, but I always suggest quality tools.
                • e30e
                  • Dec 2004
                  • 2176
                  These work very well and actually hold up decently.
                  1985 BMW 325e
                  1997 BMW M3/4/5
                  2007 Chevy Silverado Crew Cab 5.3 v8
                  • rosphill
                    • Jun 2007
                    • 187
                    Only just separating the engine/tranny so don't think these sockets are going to see heavy use. Will check Autozone today and see if they have them.
                    I like harbor freight, but you have to be careful some of their tools are cheapass. Wanting a metric tap and die set, but I noticed the ones at harbor freight are all less than $60 and look like fake kids tools...
                    • 7pilot
                      • 475
                      Torx always seem to have a bit of a sloppy fit.
                      So just in case, make sure you have a pair of genuine "vise Grips" size 10R to get you out of any potential strippings.
                      m
                      • brokenbimmer533
                        • 317
                        I managed with a an assortment of 12 pt sockets. Definitely not recommend but doable.
                        • F34R
                          sLaughter
                          • 12376
                          Get something that you can have on hand later.
                          I would get the Neiko set, couple bucks more and you get 24 more bits.
                          Instagram: @BWeissLeather
                          Current cars:
                          ~ '87 325 M30B35 swap
                          ~ '87 535
                          ~ 01 540 Msport 6spd
                          ~ '06 X5 4.8is
                          • e30s50dan
                            • Nov 2008
                            • 2076
                            i hammer the socket on to get a good fit then turn slowly..when i bought mine,i thought the same(how many times will i use these),but im on my 4th engine/trans..Got me a S50!!!!!!
                            NASA
                            BMWCCA member
                            PCA member 25yrs
                            1997 M3 sedan
                            2001 325CI DD
