g240 vs g260
  • DrFlathead
    • 42
    #46
    Lower numerically means a higher gear ratio
    • DrFlathead
      • 42
      #47
      You are right though, and runing taller gears is perfect for a turbo application, so you can actually use first gear.
      • rattlsnak
        • 45
        #48
        yeah, leave it to me to get mixed up with a project that is screwed up from the start!!
        i'm leaning heavily towards the g240 at this point!
        • DrFlathead
          • 42
          #49
          A stock m50 is very underpowered. If your overall goal is to keep the motor stock to have a nice smooth running reliable motor then go with the g240 for ease of installation. I personally would prefer a stock m50 to my stock m20 (even with perfect valve adjustment m20's sound like a sewing machine, and a timing BELT!!! on an interference motor is SO fucking stupid) even though m50's really dont have a noticeable diference in power over an m20. If your going to turbocharge it, or make power some other way go with the g260 (or like ethrty suggested go with a zf)
          • Oakman
            • 11
            #50
            I just finished dropping my M50 into my 91 318is on Monday, and after looking at both the M42 and M50 starter, they are identical as far as I can see, same part#'s on the body and all. This is due to the fact that the M42 and M50 dual mass flywheel have the exact same gear ring size with the same tooth spacing.
            • rattlsnak
              • 45
              #51
              thanks!! did you use the g240?
              • Oakman
                • 11
                #52
                Yeah I used the G240, but I don't have mine running yet, just finishing it up this weekend hopefully.
                • rattlsnak
                  • 45
                  #53
                  Just to get another idea of what you did, as compared to what other people have done, can you tell me which driveshaft, clutch setup, starter and shifter carrier/rod parts you used ?
                  • Oakman
                    • 11
                    #54
                    I used the M50 starter with the M50 dual mass FW and clutch. I will be using an E36 driveshaft and cutting down the carrier/rod for the shifter.
                    • rattlsnak
                      • 45
                      #55
                      Thanks!
