I have an M52 swapped 24V E30. As with most E30s the A/C or AUX fan is dead. It does not turn on when you press the A/C button. I have a high output pusher/puller fan. I want to put it in place of the A/C fan. Unfortunately even though it is slim I don't believe it will fit between the engine and the mishimoto :(
So how do I get at that fan? Does the valance come off? It unbolts correct? Wiring? Thinking in theory I can just "T" off the high circuit of the A/C fan so if I get stuck in traffic just pop on the A/C(and eventually when I build custom A/C lines this will still kick on the fan) and the fan will come on high power. Ideas on this? DIYs? Additional tips/help?
I did drive it and even with 80 degrees outside and sitting at lights it would only go a little over halfway. And there is no mechanic fan at all(because it won't fit).
Thanks for the help guys.
