I replaced the HG in my S50, along with timing chain cover gaskets, and Vanos gasket. I didnt replace the V cover gasket, and Intake manifold gaskets.
So after doing the work, my car starts up and has this rough idling, plus surging here and there. It is hesitant when revved, and when you let go of the accel, the rpms drop to below idling point (almost to the point of the car dying) and then the rpms go back up to normal idle level. The car sometimes dies when accelerating or letting go of the revs until it drops before idle and dies.
After leaving the car just sitting for a few weeks, I tried to turn it on and now it doent even turn on. It tries, rumbles a lot trying to start and dies. It almost feels like the car is off timing - but it should not be because the timing should be spot on.
I think I should replace the V cover gasket, intake manifold gaskets, and maybe do a valve adjustment. What do you all think.
OH and..... Yes I did spray carb cleaner everywhere and I could not find where the vac leak was that way. Sprayed it everywhere.
