can u stay using the metal coolant lines?
  • 89325iturbo
    • Mar 2004
    • 723
    can u stay using the metal coolant lines, when converting to obd1? i see people say get the rubber spider hose coolant line, and coolant pipe adapter. but why, cant you just use the the obd2 metel one?
  • Dominic49
    • Feb 2007
    • 1373
    yes I use the metal hard pipe on my s50.
    • Mossman
      • Apr 2006
      • 1961
      I'm using metal on obd1 s52 too. I think I might have had to cap off one of the nipples...I forget. I've also got throttle body heater circuit deleted maybe the return for that was to the hard pipe?
      • rThor432
        • Feb 2007
        • 3907
        ^^That's right Sam. I capped off the long pipe that runs up near the throttle body. I capped that and installed my coolant temp sensor in the throttle heater port that was tapped into the head to completely be rid of the throttle heating system.
        For what it's worth, I prefer the metal pipe highly over the spider hose. Those things are a mess to begin with, but when they fail and need replacing.. Well it's a pain in the ass to replace them in-car, to say the least.
        • 7pilot
          • 475
          Cap off the return TB to water pipe...the smaller angled fecker of the two that point to the driver side frame rail.
          m
