I killed a ground - anyone have any bright ideas?
  • sushipower
    • Aug 2005
    • 156
    Did you ground the engine??? check all your ground cables... GL
    • 1mz
      • Jan 2009
      • 641
      I thought the engine was ground through the mounts - it could very well be something that obvious. Where is the ground supposed to go?
      http://l0st0n3.mybrute.com
      http://l0st-0n3.mybrute.com
      Work in progress: 1991 318i m50 swap
      Feedback thread :up:
      I prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.
      • erik325i
        • Jan 2005
        • 3567
        It can't ground through the rubber mounts. There is supposed to be a ground strap going from the aluminum motor mount arm and the side of the frame rail.
        Erik
        • sushipower
          • Aug 2005
          • 156
          that is your problem dude... all current is flowing through that 18 gauge wire and that's why it's fried. Earth cable should be from the block to the frame. Need to replace all burnt wire and install earth cable. GL
          • 1mz
            • Jan 2009
            • 641
            bingo. I'll work it out tomorrow and post results.
            • 1mz
              • Jan 2009
              • 641
              Alright, well I'm glad someone pointed out the motor ground (seems obvious) - however I DID check for continuity from the engine to the frame before I fried it, guess it just wasnt enough though. I made a solid ground cable and fixed the harness - she cranks over again. However, the MAF is getting hot as shit with the new wire in place - like the issue was not actually fixed, just bandaged. Could the MAF be bad? Any other ideas?
              • Adrian_Visser
                • Jun 2006
                • 2823
                Hmm interesting, on my old eta the main ground was off and the starter and all accessories were grounding through the fuel injector ground from the valve cover to the firewall, it worked for god knows how long like that until I noticed.
                '89 Alpine S52 with goodies
                • 1mz
                  • Jan 2009
                  • 641
                  harness - fixed.
                  motor - grounded.
                  spark - yep.
                  fuel - replaced the filter and I stopped cranking it over before it reached the rail because the MAF was getting so damn hot; so I really don't know
                  • MattM
                    • Apr 2009
                    • 931
                    unplug the MAf and see if it will fire, odds are you fried the MAF with your lack of grounding previous.
                    Full Build Thread Here
