Wiring diagram for S50B32 EURO --> E30M3
  • Mr. Horsepower
    • 386
    Anyone got a wiring diagram for this?
    I got one for the EWS though.
    1987 BMW E30 M3 RB26
    2016 VW Polo 1.2 TSI R-Line
    Originally posted by 5spoke
    Fucking norway and your sick clean ass e30's! Yes i am yelling!
  • ChaseN
    • 709
    Theres a few pin-out maps around here of the c101, coupled with a searchable pdf of the ETM for whatever car you got yours out of, and you're in business. Just go CTRL+F through the ETM for every instance of X20, and notate what you find. I have an excel file of what worked for my car on my other computer. I could get it to you on Monday if you wanted, BUT my b32 is out of an MZ3 coupe, which has 2 or 3 differences from the M3 3.2l.
    HTH
    1991 318iS
    1992 911
    2006 330i 6-Spd ZSP people hauler
    Gone:
    1989 M3 S50B32, 6-Spd
    1990 325ix 5-Spd
    • Mr. Horsepower
      • 386
      Wow dude, not so many short words :S I must say I don't understand what you are talking about.
      I tried wiring it up yesterday without any luck, the start motor will not go around and the fuel pump will not work eater. So I think I done everything wrong then....
      • RoadHazard
        • Sep 2007
        • 163
        I got one for E30 RHD. Not sure if it's the same for M3 but I'll post it any way. Credit goes to buster and many other guys at e30zone.net.
        x20...................c101
        25 BL................1 BU Alternator d+
        2 GN/GE...........2 BU/BK oil level sensor static
        7 GN.................3 GN enable signal from ews 2 pin 4 to motronic pin 66
        12 BR/VI...........4 BR/VI coolant temp sender to instrument clust,c1 pin26
        23 BR/GN..........5 BK/BR oil pressure switch to inst cluster c1 pin 18
        22 GN/WS.........6 GN/YL Live in run&start from ign swith
        21 GN...............7 GN start sig to motronic pin 56
        24 WS/SW.........8 YL/WT Fuel output- motronic pin 46 to inst clust c1 pin11
        20 SW...............9 BK enginespeed o/p frm motronic pin47 to c1 pin7(tach)
        1 BL..................10 VI/GN oil level sensor dynamic
        19 WS/GN..........11 diagnostic connector (service reset)
        ........................12 ------ not used
        13 GN/VI...........13 VI/RD fuel pump relay to fusebox (fuse 11)
        14 SW/WS.........14 BU/YL road speed signal to motronic pin42
        15 SW/GN..........15 BK/GN starter unloader relays & inst cluster c1 pin 1
        .........................16------not used
        17 WS/VI...........17 WS/VI diagnostic connector pin 20 (tx) to ews 2.pin 2
        18 SW/GE..........18 BK/YL starter sigfrom ign switch to solenoid,via ews2
        9 BR/RT.............19 BR/YL oil temp sender to inst clustr c6 pin 2 (e30m3)
        3 splice 6821 RT/WS..20 RD/YL main relay term 87 to abs pin 10
        Pin 3 ,17 and 19 are added to the c101 connector(body side) and pin 1 and 2 are added on the engine bay side of the c101 connector
        You can double check the function of each wire with the ones in your E30 M3 ETM. And in case you don't know this yet, you should always refer to pin numbers rather than wire colors.
        90 E30 S50B30
        http://www.fquick.com/roadhazard/
        • ChaseN
          • 709
          HTH
          Sorry...
          ETM: Electronic Troubleshooting Manual (basically BMW's wiring diagrams)
          pdf: an adobe acrobat file
          CTRL+F: A shortcut for searching in adobe acrobat. Hold the "control" and the "F" key at the same time and you can search for stuff
          X20: The e36 engine harness/chassis harness connector's name
          c101: The e30 engine harness/chassis harness connector's name
          MZ3: The "M" version of the Z3, which came with the s50b32 in europe
          These are all standard acronyms/terms you should probably already be familiar with if you are serious about tackling this swap. Seriously though, I would double check any adapter map you get by going through the ETM's. I probably spent 10-15+ hours just going through wiring diagrams to create my own personal adapter map for the x20/c101 junction, not to mention the EWS, all the grounds, power supplies/distribution, fuel pump relay harness, etc. And the best part was, my b32 fired up the first time I turned the key. Remember, the MSS50 DME does not take kindly to stray +12vdc flowing where it shouldn't be...
          1991 318iS
          1992 911
          Gone:
          1990 325ix 5-Spd
          • Mr. Horsepower
            • 386
            Got her fired up, but new problems is discovered. The diagram I used is nothing like the one posted over here. See new thread for the problems I have discovered.
            Starting to get pretty frustrated now....Started the project late january and not done yet!
