need fan help, asap.
  • sefb222
    • Apr 2007
    • 1206
    i need to install a fan in my S52 car. asap...
    in the cooler months, it does fine with no engine fan (i do have the aux fan), but with summer fast approaching, and with the car seeing more use, i need more cool.
    when there's no traffic, the temp seldom goes above the 1/2 way point, but with the slightest bit of stop n go, it starts climbing into 3/4 and beyond... not where i want to be. i literally had to pull out of traffic the other day and haul ass up the shoulder, to avoid an overheating situation.
    im running an E36 radiator, and AC.
    that leaves me with literally 2" of clearance, and room for roughly a 16" diameter puller fan.
    im thinking of this one:
    Free Shipping - Be Cool Qualifier Fans with qualifying orders of $109. Shop Fans, Electric at Summit Racing.
    Brand
    Be CoolManufacturer's Part Number
    75058Part Type
    Fans, ElectricProduct Line
    Be Cool Electric FansSummit Racing Part Number
    BCI-75058
    Maximum Fan CFM
    1,300 cfmFan Quantity
    SingleFan Diameter (in)
    16.000 in.Height (in)
    15.750 in.Width (in)
    16.250 in.Thickness (in)
    2.000 in.Number of Blades
    10 bladesBlade Material
    PlasticBlade Color
    BlackShroud Color
    BlackShroud Material
    PlasticAmp Draw
    7.50 ampsQuantity
    Sold individually
    thoughts?
    thank you.
    Originally posted by Holland
    There should be a restraining order to keep kids 100 feet from that car at all times. Plus execution on the sight to anyone who places a shopping cart within 200 feet of the thing.
  • MR E30 325is
    • Dec 2008
    • 3300
    I run my stock E30 fan on my S52, and even though its close I have no rubbing or hitting issues.
    I drive the car in Phoenix frequently, and I have the stock front aux fan wired to a switch in the cabin. As soon as I hit traffic I flick it on, and I turn it off when I start cruising again. I havent had a single overheating problem yet.
    Just as a side note, is your system properly bled, and full of coolant?? Could be the culprit.
    My previous build (currently E30-less)
    http://www.r3vlimited.com/board/showthread.php?t=170390
    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
    • sharky
      • Jan 2005
      • 2672
      I run a Mishimoto 16" pusher in front of my condensor and Mishimoto rad. I run a cooler thermo stat and mech fan delete. It was 97 here 2 days ago, drove the car pretty hard all day and in traffic and never touched more than 1/2 on the cluster
      • 748Snowman
        • 55
        How do you have your pusher fan hooked up? I don't want to run a switch inside the car I would rather use the high/low switch on the radi. Also I plan on running the Mishimoto, might you have a part number for the one you used?
        Sorry one more question, does the Mishimoto require a reservoir tank?
        Sorry didn't mean to thread jack. ;)
        • 87e30
          • Jul 2008
          • 5676
          I had this same problem yesterday! First time my m52 has gone above 1/2... except I have a little ebay fan and it was doing it's best to keep me around 3/4 in traffic.
          Will stay tuned to this thread.
          I just hate everyone.
          No need for discretion.
          • Wh33lhop
            • 11705
            I've been in the same situation, had to pull out of traffic, douse the rad with water, leave the hood popped and haul ass up the shoulder.
            I deleted my condensor, got a Z3 temp switch and 1600CFM 16" SPAL fan and wired it up like stock, hasn't let me down.
            paint sucks
