Show better pics, more zoomed out. The first one may be the solenoid which is for the charcoal canister. Is the second one on the drivers side near the p/s pump?
The two wires could be for the ASC+T throttle actuator that's mounted on the e34/e36 body. When i got my engine those two wires had to be cut because there was no plug connecting them to the unit. The others look like plugs from the automatic transmission. If the O2 plug was cut as well there should be 4 more wires there so i think you're ok.
