Ok finally got my stock gauge working correctly today thanks to matt and mccoy over at TRM. they were able to down size my M20 sensor to M12x1.25
anyways my cooling system is stock e36 radiator, stewart water pump, 325i 80/88 thermostat and the lower temp fan switch as well. Stock e30 aux fan
needle got to half way mark in cluster and then it went past half way a tad (left side of needle was touching right side center marking) thats when the fan cut on and the needle went back to half way mark.
so pretty much my needle gets to half way as expected, rises to past halfway slightly fan cuts on and goes back to half way.
i dont really seem too worried about it other than the fact that so many others on here seems to chime in and swear how proud they are that their stock cluster needle gauges always stay below half way mark and never budge.
it makes sense to me that te e30 needle will read higher than middle because 24valve engines run hotter than stock, even with a lower temp thermostat with a little hole drilled doesnt seem to effect the temp gauge reading much if any
and the people who have gauges reading below half way all the time i think are not reaping the benefits of an engine that was designed to run hotter which makes more power and is more efficient.
BTW i do really like the E30 temp gauge much more than the e36 one. as the E30 one actually moves i real time compared to the e36 one that doesnt or not at as much at least.
