half assed swap - need help fixing it
  • dannyb
    • Dec 2009
    • 27
    So I had a shop do my swap, it proved to be a bad decision since ive been fixing vaccum leaks and plugging a bunch of wires that just left hanging.
    My temp gauge isnt reading any temp, i tested the temp sensor and it seems to work. Then I decided to look at the connection from the engine to the body. Seems like there might be misplaced pins and one missing. Can anyone tell me if this is right:
    Thanks
  • Jean
    • 18228
    They don't all have ALL pins...you need to post what build year is your car/ what harness you are using/what engine.
    • dannyb
      • Dec 2009
      • 27
      Build date for the car is 12/87, engine is OBDI M52B28
      • nrubenstein
        • 3148
        Also, what you've posted is pretty much meaningless. You're going to have to peel back the covering on the engine harness side and start comparing wiring colors with the charts.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • dannyb
          • Dec 2009
          • 27
          thanks will do
          • gregslow318i
            • Sep 2007
            • 1918
            missing pin in the adapter is for the abs 12v+
            your temp gauge prob is because the shop used the e36 sensor instead of the e30
            looking for a e30m50 swap harness adapter pm me $150 shipped
            email nitroman12@gmail.com
            • MR E30 325is
              • Dec 2008
              • 3300
              Exactly. The car needs the single pin E30 brown top temp sensor, not the two pin E36 one.
              My previous build (currently E30-less)
              http://www.r3vlimited.com/board/showthread.php?t=170390
              A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
              • dannyb
                • Dec 2009
                • 27
                it wont get a reading at all if its the e36 one?
                • 325issguy
                  • Dec 2005
                  • 261
                  No reading at all with the e36 one... The e30 one is necessary.
                  • dannyb
                    • Dec 2009
                    • 27
                    so this is what i need?
                    http://www.autopartsway.ca/autoparts...W~325is~242071
                    • MR E30 325is
                      • Dec 2008
                      • 3300
                      Yep, thats the part you need.
                      • dannyb
                        • Dec 2009
                        • 27
                        Thanks guys, that fixed the gauge problem. Now i just need to find a charcoal canister to remove the CEL.
                        • nrubenstein
                          • 3148
                          The evap solenoid is separate from the charcoal canister. You can just plug it in to clear the cel temporarily.
                          • dannyb
                            • Dec 2009
                            • 27
                            Probably dont have it, where would it be located? The shop left some vaccum lines unplugged and i didnt see anything that it could plug into but i might have missed it. I have the TB vaccum line plugged with a bolt and clamp right now.
                            • nrubenstein
                              • 3148
                              It's probably still located in the E36 donor car. :p
                              IIRC, the charcoal canister line (use the stock E30 canister) plugs into the throttle body. So, if you've got that hose nub on the bottom plugged, you know where to go with the line.
