S50 3.5 HFM Question
  • e30s50dan
    • Nov 2008
    • 2076
    Ok...getting ready to install this S50 soon.I have a set of 21.5 lb injectors,but no 3.5/euro HFM yet!.
    Does the 3.5 HFM make that much of a difference in performance??
    tring to decide on which TRM chip to order.with or without the HFM,or just injectors/light flywheel.. i have a lead on a euro HFM!!
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
  • nrubenstein
    • 3148
    Yes, it makes a noticeable difference. Don't skip it now.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • psyber_0ptix
      • 904
      hmm....i have to research the cost/benefits of this more. surely they are all items that can be added later right? I have yet to swap the s50 in, but haven't justified the upgrade yet until i get all the drivetrain parts sorted.
      Originally posted by FredK
      However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
      My year in Germany
      Feedback
      • matt
        • 3732
        Just so you're aware, if you want to change your chip later there's usually no extra fee for that, just pay shipping both ways and whatever extra $ the upgrade would be.
        And PM me when you're ready to order so I can send you a coupon code. :)
        • e30s50dan
          • Nov 2008
          • 2076
          ^^^ yea that another $50 huh! I will let you know Matt
          NASA
          BMWCCA member
          PCA member 25yrs
          1997 M3 sedan
          2001 325CI DD
          • Adrian_Visser
            • Jun 2006
            • 2823
            Does it really make that much of a difference though? I know that matt himself has said it makes a marginal difference. I have a 3.5HFM and I sent my chip to trm to get re-burnt for it but I'm just sayin...
            '89 Alpine S52 with goodies
            • e30s50dan
              • Nov 2008
              • 2076
              can you tell the difference Adrian...looking for some numbers
              NASA
              BMWCCA member
              PCA member 25yrs
              1997 M3 sedan
              2001 325CI DD
              • Adrian_Visser
                • Jun 2006
                • 2823
                I have nothing to compare to my engine has had the 3.5 HFM on it since I first started it, my DME came with a chip for no HFM though.
                • e30polak
                  • 6136
                  I used both on my car, and they behave differently. I saw a bit more low-end with the 3", and more top end with the 3.5". It may have been a placebo effect, but throttle response was definitely better with the 3"
                  INSTAGRAM: @UNDR8D_EMPIRE
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    Really? I thought it was supposed to get better with the 3.5" MAF.
                    • JJe30
                      • 2044
                      I'm doin the 3.5" HFM upgrade now but I won't be able to tell a diff just from that. m50 is getting s50 cams, pink top injectors and TRM chip all at the same time.
