Quick Question! Pictures included. OBD1 Filter Housing on M52
  • 87e30
    • Jul 2008
    • 5676
    I've seen other engines with this done. And am inthe process of doing it. I spaced the power steering pump out to line up with the lines, but I'm 1/8th of an inch out too far approximately. Will that be okay? What do the rest of you guys do?
    I just hate everyone.
    No need for discretion.
  • dude8383
    • Jan 2005
    • 10387
    That's really strange, your pump looks nothing like mine...
    Honestly 1/8" sounds like too much play. Maybe you can use smaller washers?
    • Danny
      • 14216
      Just take one of those nuts and grind an 1/8" off of each one.
      • dude8383
        • Jan 2005
        • 10387
        WERD. That works too.
        • 87e30
          • Jul 2008
          • 5676
          I don't have a grinder. And it's all back together now... it all fit perfectly and doesn't seem bad.
          What will go bad first if it is indeed too far out of line? Strain the pump?
          • 87e30
            • Jul 2008
            • 5676
            And it's less than 1/8th of an inch, I don't think that I could get it closer even with washers.
            • dude8383
              • Jan 2005
              • 10387
              You'll put stress on the belt me thinks, it will decrease the life of it. Maybe someone else can confirm if thats true or not.
              • surebimmer
                • Jan 2004
                • 978
                Doesn't look like you routed the belt correctly. Where is your idler pulley? Better picture shown the belt routing would help.
                Should be like this picture http://www.fixya.com/uploads/Images/8E7EFB1.jpg
                • jahnaboi
                  • Oct 2006
                  • 1742
                  Lol... where's your alternator...
                  SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
                  • 87e30
                    • Jul 2008
                    • 5676
                    Correct. No alternator yet because I was still debating if I wanted to run the pump like this.
                    Fire up the car and no noises, it looks fine. The belt is routed properly now that the alt is there.
                    I guess I'll go with this and hope for the best. I'll keep an eye on it. Really curious what others with the same setup have done.
                    • 10Toes
                      Me Father Was A Tree
                      • Jan 2008
                      • 61222
                      Does this mean you no longer want the plastic housing cap?
                      • jahnaboi
                        • Oct 2006
                        • 1742
                        Why don't you just go to the junkyard to pick up a proper power steering pump? Pretty sure there would be a lot and you could rebuild it fairly cheap as well.
                        • dude8383
                          • Jan 2005
                          • 10387
                          They had several ways of routing the belt...my motor's belt is routed the same way as O/P...no secondary idler pulley required.
                          • gregslow318i
                            • Sep 2007
                            • 1918
                            I have an obd1 ps pump if you need one clayton
                            looking for a e30m50 swap harness adapter pm me $150 shipped
                            email nitroman12@gmail.com
                            • evil_twin
                              • Nov 2007
                              • 2965
                              Why don't you spend $15 from the guy that machines them? :)
                              Paypal: vdang5@gmail.com
                              Delta Auto Care
                              2875-C Towerview Road
                              Herndon, VA
                              703.435.1375
                              My Feedback Thread: Evil_Twin
