so after i put in the S52 i just left the evap line open because i no longer had my evap canister. when i got to the exhaust shop it was pouring fuel from the line under the hood even after i turned the car off.
so i blocked it off and it eventually began leaking from the tank. the very top of the tank was leaking fuel from the spot where it looked like a hard line is connected to the fuel tank (sorry, hard to describe)
ok so changed the fuel tank. worked fine for a while and now it leaks fuel again from the top of the tank. idk if its the tank itself again but it seems like it. it just drips a bunch after i drive it for a bit. i also noticed a lot of pressure was released when i opened the gas cap which makes sense but how is fuel leaking from the top even when my tank is almost empty. also if i just reinstall an evap canister and run it to the intake mani and fix the leak in the tank, will that take care of the issue or is there something else going on here.
