Does anyone know if the line that run back to the overflow take from the spider hose is a return back to the engine? Or is it a return from the engine to the overflow tank. I would assume it flows from the tank back to the engine through that hose...but am not 100% sure.
The reason I ask is I am installing a m42 into a 1967 2000c and was not able to fit a radiator with the build in res tank so I just plugged that hose as I THINK it is a return from the res tank which I don''t have. I am running an e30 318(m10) radiator.
jake
jake
