Do I need a new/different Transmission?
  • jajou318
    • Jan 2005
    • 1023
    I am planning on doing an engine swap but I called some place and they gave me a price on the labor and engine but did not specify whether or not a diff. transmission was needed. I am not a mechanic so I wouldn't have a clue but I am guessing that it does. So do I?
    Thanks,
    Tony
  • clutterbucker
    • Jun 2004
    • 481
    the Getrag 260 (E30 6cyl) transmission is said to be a direct fit.
    If you are coming from a 318 of any sort the transmission will most definately not fit.
    - 2000 Audi S4 Stg 2 (sold)
    - house (bought)
    - 1997 Civic Hatch (shaky but driveable)
    - 2010 Sportster 1200 Forty Eight Ed. (vroom)
    - 1991 318is S50B30 (TBA)
    • jajou318
      • Jan 2005
      • 1023
      Thanks.
      • clutterbucker
        • Jun 2004
        • 481
        now that I read further into all this stuff, some people say it doesn't line up perfectly, and that new/different/custom mounts are necessary.
        I'd wati till someone else chimes in, my M50 isn't in yet.
        - house (bought)
        • Brew
          • 3060
          Read the thread.
          Until then, yes, the e30's getrag 260 will bolt up to the m50, albeit at a slight angle. You either need to have the flywheel lightened and some material removed from the front face of it, or grind down a couple castings on the oil pan. And you should fabricate a new transmission mount bracket to account for the angle of the tranny.
          But like I said, read the twin cam thread. It has all that info and much, much more.
          '91 318is
          • skatebline
            • Sep 2006
            • 167
            Originally posted by Brew
            Read the thread.
            What will happen if the flywheel isnt lightened and some material removed from the front face of it, or grind down a couple castings on the oil pan???????:(
            • 325Projectz
              • Jan 2005
              • 1956
              if you don't do that, when you go to turn over your motor it will not spin.
              91 m3
              • DEV0 E30
                • Oct 2004
                • 8904
                Which is oh so fun.
                Ask me how I know.
                • skatebline
                  • Sep 2006
                  • 167
                  Oh shit lol i didnt do that and the tranny is already on.....
                  Soo how do you know lol
                  • DEV0 E30
                    • Oct 2004
                    • 8904
                    Put a 22/24mm? wrench on the front of the engine. If it spins, you're ok. If it doesn't, you're not ok.
                    • 325Projectz
                      • Jan 2005
                      • 1956
                      i would pull the tranny off and check the clearance... if the motor is out of the car, you don't have an excuse not to.
                      91 m3
                      • skatebline
                        • Sep 2006
                        • 167
                        yeah its out of the car right now..........i wanna get in by the end of the weekend.
                        so if the crank turns over when its in gear or neutral...? im ok
                        • 325Projectz
                          • Jan 2005
                          • 1956
                          if the flywheel is pinched against the oil pan, it doesn't matter if the trannys in gear or not. do yourself a favor, remove the 6 or so bolts, then the trans and check it.
                          91 m3
                          • skatebline
                            • Sep 2006
                            • 167
                            Yep sure shit it didnt turn over.... i ended up taking it all apart and got the flywheel resurfaced and also on the back side of the flywheel had .060 takin off, and now its all good and turns over :)
                            • 325Projectz
                              • Jan 2005
                              • 1956
                              hahahahhahahahahahahahhahahahahahahahahhahaahhahaa hhahaha
                              hahahahahahahhahahahahahahahhahahhahahahah
                              can i say i told you so!?
                              91 m3
