Pilot Bearing - s50 + getrag240
  • psyber_0ptix
    • 904
    OK folks, I have a couple questions as to which Pilot Bearing to use. A lot of people have said if using a getrag240 with m20 flywheel/clutch/pp to use the m20 pilot bearing (12x32x10)
    "You use the M20 single mass flywheel, pressure plate, and disk and a euro 323i throw out bearing with a m20 pilot bearing."
    "use pilot bearing that was meant for your motor"
    from what I gather these bearings come in two flavors....
    12x32x10 and 15x32x10
    Why would you use the pilot bearing that belongs to the motor when the outer diameter and depth is the same. Shouldn't it be matched to the input shaft of the transmission being used?
    I don't understand the logic of running say... a 15x32x10 where an input shaft is 12mm when the shaft would never sit contacting the bearing. why have the bearing at all?
    That being said, which bearing would I run for the getrag240 for a 91 318i if using an M20 single mass flywheel/clutch/pressure plate mated to an s50?
    Originally posted by FredK
    However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
    My year in Germany
    Feedback
  • blackhawkimpact
    • 2415
    I used a Euro 323i throwout bearing part # 21-51-1-204-525 on my 318is with s50 and m20 setup
    edit: thought i read throwout bearing....use the m42 bearing that's what i use since the m20 bearing is too small for the input shaft (m42=15mm hole, m20=12mm hole)
    • mega_t2008
      • Nov 2009
      • 43
      It doesn't matter what kind of clutch are you using... Pilot bearing MUST be in there, and must be matched to input shaft of gearbox... So if you use newer gearbox(M5x,S5x) then inner diameter of the bearing should be 15mm, and if you use older gearbox (M20) then inner diameter should be 12mm...
      And, no... You're wrong... Input shaft will be nested in pilot bearing all the time...
      • psyber_0ptix
        • 904
        When talking about the input shaft and pilot bearing....it was more a rhetoric of why have a smaller input shaft hovering concentrically in a larger inner diameter bearing where it wouldn't touch unless some serious deformation were to occur. Not so much that it wouldn't be positioned at the center of the bushing. This is the picture I get of those who are using the wrong pilot bearings for the "motor" application. Obviously the input shaft SHOULD be nested in the pilot bearing. But when is it actually useful the input shaft never contacts?
        i'll use the m42/getrag240 pilot bearing (which also happen to be 15mm from 9/1990-on) contrary to previous members' experience. thanks blackhawkimpact for the insight, I have the euro throughout bearing all itching to be installed.
        and thanks for the responses clarifying misinformation
        My year in Germany
        Feedback
        • e30s50dan
          • Nov 2008
          • 2076
          I am also installing an S50/g240 and mine measures 12mm. Iam using am20 fly/clutch sport pp Hopefullllly it will be in next weekend
          NASA
          BMWCCA member
          PCA member 25yrs
          1991 318IS slick top
          1997 M3 sedan
          2001 325CI DD
          “whoever turns the wheel the least, wins"
          • blackhawkimpact
            • 2415
            Your pilot bearing is 12mm? Your transmission will not go in/fit.. It has to be 15mm if you're using g240.. ask me how I know.
            • e30s50dan
              • Nov 2008
              • 2076
              NO its 12mm for sure!! measured shaft 11.53mm to be exact
              NASA
              BMWCCA member
              PCA member 25yrs
              1997 M3 sedan
              2001 325CI DD
              • psyber_0ptix
                • 904
                the plot thickens....
                My year in Germany
                Feedback
                • lifeiskaos
                  • 1709
                  I'm also using a 12mm pilot bearing with my m52 and g240. Ordered the 15mm by accident and it was way too big.
                  • psyber_0ptix
                    • 904
                    What production date is listed on your 318i's?
                    mines 02/1991
                    Both Pelicanparts and RealOEM list 15mm for all post 09/1990
                    My year in Germany
                    Feedback
                    • lifeiskaos
                      • 1709
                      i dunno, came from a 91 318is so it may be a 1990 build date. I ran into the same issue, which is why I ordered the wrong one. I think realoem and pelican list the part for the e36 m42 which has a different transmission...
                      • psyber_0ptix
                        • 904
                        gottverdammt
                        My year in Germany
                        Feedback
                        • blackhawkimpact
                          • 2415
                          Maybe thats why mines is 04/91 thats why i used the 15mm
                          • psyber_0ptix
                            • 904
                            ok, I feel better
                            thanks guys lol
                            My year in Germany
                            Feedback
