Ok well I have a 325ix booster and m5 master cylinder. MC bolted up finem but the booster does not fit at all.... Theres only 2 bolts to screw the booster to the body and the original had 4, The width between the bolts too is different, the 325ix is smaller than the stock one.
Anyways, Im thinking about just drilling new holes, problem solved. I have a question though,
1. I have to run a remote res. for the brake fluid, is there hi pressure lines or anything I need to do this? Or will some rubber hoses work?
2. If its remote does the 2 holes for the res, have to be facing straight up? Or can it be cock eyed a bit?
3. The hose coming out of it to go to the engine used to be on the bottom right, does it matter where it is? It easier to swivel the booster so its kina in the middle.
Thanks!
Oh btw, this is going in a e30 m3 to throw a couple kinks at ya
Thanks!
