S50 oil pressure
  • e30s50dan
    • Nov 2008
    • 2076
    S50 oil pressure
    JUST got done with my S50 swap,and the damn thing cranked right up,runs great...chaseing an oil leak,and have to order software,as I have 21.5 injectors and this red label is from a M50
    I have an mechanical oil pressure gauge strapped to the manifold,so I can see it from inside (hood off)....Ive noticed the oil pressure is around 20-25psi at idle,but 70+psi at higher rpm's..IS this normal??? I cant remember what the M50 was!
    I am running 10-30w right now as break-in(head rebuilt)bottom end wasnt touched...plan on going with heavier weight oil this week
    so, is 70-72 psi normal on an S50??
    tia
    Dan
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
  • gobuffs
    • Dec 2004
    • 513
    general rule of thumb is 10psi/1000 rpms. Idle of 20-25 psi is normal.
    • e30s50dan
      • Nov 2008
      • 2076
      Yea but at 5k rpms I'm seeing 70psi. Seems high
      NASA
      BMWCCA member
      PCA member 25yrs
      1997 M3 sedan
      2001 325CI DD
      • matt
        • 3732
        I wouldn't worry too much about it. I see 60 pretty regularly, a little more is no big deal.
        It can also depend on the gauge and where you have it tapped.
        • e30s50dan
          • Nov 2008
          • 2076
          Thx Matt. Going to order your chip this week
          NASA
          BMWCCA member
          PCA member 25yrs
          1997 M3 sedan
          2001 325CI DD
          • BMW_TUNER
            • Jul 2006
            • 1386
            Yup the S50 with thin oil will make the factory light flicker at idle sometimes I checked mine and it was 22 at idle. The light comes onat anything uner about 22.
            1989 332IS -S-Fiddy Four-Some weight removed.
            5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
            • StereoInstaller1
              GAS
              • 22679
              What oil you rockin?
              Closing SOON!
              Thanks for 10 years of fun!
              • e30s50dan
                • Nov 2008
                • 2076
                right now,just 10-30 Mobil one dino,but changeing to heavier weight....any suggestions!!
                run 15-50 Mobil 1 synth in race car,been for years,but its not what it use to be.I have some of the last red top bottles,and not sure what to use
                NASA
                BMWCCA member
                PCA member 25yrs
                1997 M3 sedan
                2001 325CI DD
                • Fusion
                  • Nov 2009
                  • 3659
                  I think it's the oil. Either the weight or the fact that it's new, that's raising the pressure.
                  Click http://www.r3vlimited.com/board/show...14#post2092414
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    Thx for that thread. Good info
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1997 M3 sedan
                    2001 325CI DD
