Identifying Parts and COnnectors Help
  • SwiftE30
    • Jun 2010
    • 998
    This MAF came from a 95 e36 325i. Im have a 97 M3 S52. I was told the connectors would match up. I just think i got the wrong part.
    1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
  • tangkenboo2
    • Nov 2005
    • 799
    photobucket is your friend.
    [PAKSIW]
    20D .........
    vmwerks :up:
    ryan gmw :up:
    • SwiftE30
      • Jun 2010
      • 998
      haha im workin on it
      • MattM
        • Apr 2009
        • 931
        MAF's came in 6 pin or 4 pin form, im not sure which cars had which. but looks like you need the 4 pin one.
        the fourth pic could be the purge valve, whats the number on the side?
        the rest im going to need wire colors...
        Full Build Thread Here
        • SwiftE30
          • Jun 2010
          • 998
          Ill get the numbers and colors for you tomorrow when I get off work.
          • e30s50dan
            • Nov 2008
            • 2076
            that maf is from a 92 M50nv
            NASA
            BMWCCA member
            PCA member 25yrs
            1991 318IS slick top
            1997 M3 sedan
            2001 325CI DD
            “whoever turns the wheel the least, wins"
            • SwiftE30
              • Jun 2010
              • 998
              Pic 3: both are; red/white wire and purple/green wire
              Pic 7: left connector is tan/brown wire and a tan wire
              • M3 euro ltw
                Site Sponsor
                • 259
                pierburg
                That part is most likely for the secondary airpump plumbing.... some vacuum lines go to and from it, and one likely went to the pump too....there is most likely a bmw part number stamped on it, confirm with Realoem.com
                I don't think its big enough to be charcoal cannister purge valve etc...
                Trying to make the world a better place, 6 TB at a time.
                http://abloriginalparts.com/
                • Mr. Horsepower
                  • 386
                  Pic 3 seems like water temp around cyl nr 1 on the head, the longest of the two.
                  The other is probably oil temperature OR pressure located on the oil filter console located just under the water temp I'm talking about.
                  1987 BMW E30 M3 RB26
                  2016 VW Polo 1.2 TSI R-Line
                  Originally posted by 5spoke
                  Fucking norway and your sick clean ass e30's! Yes i am yelling!
