525 harness
  • R&D man
    • 79
    525 harness
    I had to purchase a 525 harness with automatic................Is there anyting I should whatch for on this harness?will It work for my m50 vanos engine?
  • Schwarz325
    • Aug 2009
    • 487
    Is it a original vanos harness? and if your e30 is manual you'll need to convert it to a manual harness
    • R&D man
      • 79
      harness
      How do I know if it a automatic I only have one plug for the ecu?
      • Kingb
        • 928
        I have heard this a lot but also read from people that they didn't have the extra connectors for the auto. I pulled the auto tranny off my m50 and it didn't have any extra connectors or wires. My guess is that it will depend on which car is the donor and which auto was in it
        Originally posted by Nicademus
        My car beats off to that car. :bow:
        • xwill112x
          • Jan 2009
          • 4236
          91 318<--nvm50e34auto
          i just cut all the wires to the auto. i thinkk i should be fine?
          • g22
            • 274
            I used an auto 525 harness. I had no problems.
            • matt
              • 3732
              Your ECU would fit where it is supposed to if you had an e36 harness. Otherwise it's fine.
              • 318isbmw
                • Nov 2005
                • 2843
                Honestly i didn't even cut out the auto parts of the harness. I'm running an e36 harness and like matt said, the ecu fits just like the old one.
                • OldsCool
                  • Jan 2009
                  • 157
                  same here. but my engine was an NV M50. used a auto harness and had no problems.
                  • genocide98
                    • Oct 2009
                    • 106
                    The automatic portions of the harness are optional if you're using a manual transmission. If you cut them off make sure you seal the ends up with tape and heat shrink... but I'd just leave them on unless you're anal about cleanliness and weight.
                    I know that my e30 had a neutral start switch I had to jump when I swapped my 5spd, but I'm not sure if thats the case with an e34/e36 harness, or if you would even have that portion of the harness from the car.
                    • bmw320e21
                      • Jan 2005
                      • 67
                      On the e34, the transmission harness is not apart of the engine harness. Its two separate harnesses. So you wouldn't have to remove anything.
                      Adam
                      • BonnschE30
                        • Jun 2008
                        • 295
                        Any creative solutions to fixing this problem? I hate non-OEM fitment of anything!!!!
                        • g22
                          • 274
                          I used the 318 ecu bracket turned sideways and two of the four screws fit. Once I get time I'm going to weld two small strips of metal to reach the other two screws. Two holds it fine though...
                          • BonnschE30
                            • Jun 2008
                            • 295
                            e36 or e30 318???
                            • g22
                              • 274
                              I think it was an e30
