Riddle me this S50 batman
  • e30s50dan
    • Nov 2008
    • 2076
    OK
    installed My S50 in my 88 325is last weekend,and started right out of the box..couldnt be happier :) :) :) I could start, idle and drive(no far)because the red label 413 was from a M50..so happy as i was I ordered an aftermarket chip for an S50 21.5lb injectors ltw fly...couple days later I received such chip...installed and NO START!! ok so I went back to the M50 chip...still NO START!! WTF.
    Started looking fuel or spark..got the starting fluid sprayed some on the air filter cone , hit the key,and it will try to start,so sounds like fuel....checked fuses/relays OK..removed fuel line to fuel rail,hit the key and shot up like ol' faithful..will check tomorrow with fuel gauge,but seems to be getting fuel.sprayed starting fluid in boot and BAM tries to start.
    ANY ideas??,because ,Iam stumped!!!!
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
  • F34R
    sLaughter
    • 12376
    Originally posted by e30s50dan
    OK
    Crap out your ECU, fry you main relay?
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • StereoInstaller1
      GAS
      • 22679
      Got voltage at fuel pump relay? Fuel pump fuse OK?
      Closing SOON!
      Thanks for 10 years of fun!
      • e30s50dan
        • Nov 2008
        • 2076
        Fuse is ok. Not sure which one is the relay BUT crap load of fuel at fuel rail this thing started would idle all day long last weekend
        yes I'm leaning towards ecu. May have craped out. That's the only thing I touched
        NASA
        BMWCCA member
        PCA member 25yrs
        1997 M3 sedan
        2001 325CI DD
        • Fusion
          • Nov 2009
          • 3658
          You installed the chip wrong, you can put in in both ways.
          Just flip it around, it shouldn't be fried.
          In my internet journeys, I have found that some people had this problem even though they installed the "dot" on the new chip the right way. Same thing happened to me. I was like oh fuck, dme died. Flipped the chip, all is fine.
          Also check that all the "legs" are nice and straight and in pisition. They're so easy to bend that if you pushed the chip in with a bent leg, you might not even notice it. Be careful because I think two or three bends and the leg is gone.
          • e30s50dan
            • Nov 2008
            • 2076
            I thought that but I was 100% positive as I marked it before I removed it The small notch is the same on both. So if that was true. Why doesn't it start with orginal chip back in I am positve it was correct but I will try reversing it in the mourning
            NASA
            BMWCCA member
            PCA member 25yrs
            1997 M3 sedan
            2001 325CI DD
            • matt
              • 3731
              That's why I asked if you have a check engine light... if the chip is wrong, you will not have it when you key on.
              Very strange issue. Maybe the fuel injectors are not getting power for some reason? There are a number of different ground and 12v wires that feed the ECU to power various things. Maybe one has come loose?
              • e30s50dan
                • Nov 2008
                • 2076
                Ok. I think I found the problem after closer look under the chip I see a broken solder line. I must have did it with a small screwdriver. Damn it.
                In need of a red label 413. I have a 402 and silver label 413 for trade
                NASA
                BMWCCA member
                PCA member 25yrs
                1997 M3 sedan
                2001 325CI DD
                • matt
                  • 3731
                  Just put the chip from me into the silver label... it will run.
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    It will?? I'll try it thx
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1997 M3 sedan
                    2001 325CI DD
                    • e30s50dan
                      • Nov 2008
                      • 2076
                      LADIES AND GENTLEMAN MATT IS THE MAN!!!
                      threw in the silver label ecu and started right up... B E A utiful
                      thanks everybody..............this forum rules!!
                      NASA
                      BMWCCA member
                      PCA member 25yrs
                      1997 M3 sedan
                      2001 325CI DD
                      • dude8383
                        • Jan 2005
                        • 10387
                        LOL
                        Good stuff man. Hopefully I'll have the same revelation when I get my new pump.
