S50 Drivetrain: Driveshaft question
  • rbartongrimley
    • May 2008
    • 286
    I am getting ready to do my swap, and I am using the entire power train out of a 95 M3 (meaning I am using the s50 engine and ZF transmission). I am contemplating what my drive shaft configuration will be. I know what the typical combination's are, but I want to know what people have used on this specific engine/transmission set up. Thanks!
    Do Work www.sbeuroclub.com
  • tangkenboo2
    • Nov 2005
    • 799
    -S5X
    -zf tranny
    -e36m3 driveshaft
    [PAKSIW]
    20D .........
    vmwerks :up:
    ryan gmw :up:
    • nrubenstein
      • 3148
      You need the 328i or OBD-II M3 driveshaft. As you've probably noted, the '95 driveshaft has a CV joint, while the later ones are u-jointed.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • rbartongrimley
        • May 2008
        • 286
        Originally posted by tangkenboo2
        -S5X
        -zf tranny
        -e36m3 driveshaft
        That is specifically what you used?
        Yea, I had come to the conclusion and realized from all my reading that 96+ is needed.
        • tangkenboo2
          • Nov 2005
          • 799
          everything i used is obdII
          [PAKSIW]
          20D .........
          vmwerks :up:
          ryan gmw :up:
          • rbartongrimley
            • May 2008
            • 286
            So, I am gathering from your post that the OBD-2 drive shaft was a complete bolt up? Did you switch out the CSB?
            • tangkenboo2
              • Nov 2005
              • 799
              nope i just slotted mine so i would be able to bolt it straight up. reason for me not changing it is cause it was new. next time around i'll switch it out with an e30 CSB
              [PAKSIW]
              20D .........
              vmwerks :up:
              ryan gmw :up:
              • nextelbuddy
                • 134
                USUALLY but there are a LOT of 96 M3s out there that still had the UV joint style DS. to be safe you need to find a 97+ E36 328i/M3 manual drive shaft that has the 4 bolt rear.
                i could not find one ANY where unless i ordered a rebuilt one online. no salvage yard had one and they were always snatched up quickly on forums or too expensive for shipping.
                i ended up just taking the rear half of my DS from my automatic E30 along with a new e30 CSB and my UV jointed 96 M3 DS to a reputable DS shop along with dimensions from the Tranny Flange WITH the GUibo bolted on to Diff Flange face and said make this work.
                389 dollars later i had a completely rebuilt and balanced perfectly fitted slipyoke DS for my car thatys better than brand new.
                yes it was pricey but i would have rather spent the money after 4 months of searching instead of cursing at the computer screen at other people beating me to cheap DS's on forums because they are online 24/7 hunting parts since i have a full time job and dont have time for that.
                you can also use a 86-87 Large Guibo Manual Drive shaft from an e30 ETA
                • SwiftE30
                  • Jun 2010
                  • 998
                  If i have a fully intact 97 E36 M3 i can use the engine, transmission, and the driveline? How would this hookup to an e30 diff?
                  1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
                  • xwill112x
                    • Jan 2009
                    • 4236
                    as long as it has the 4 bolt rear section it should just bolt right up
