ready to turn the key
    I will be ready to start my engine this weekend on my m50 swap.I have double checked all the connections and grounds .Is thers a checlist that I should go through before I start the engine .I might not have the exauhst hooked up for the start up .,,wil it run with the o2 sensor plugged in but not in the pipe?
    There is a check list on here. Search and yea the engine will run without o2 just run rich. Good luck. Just swapped in s50 last weekend. Great feeling. Now just allllott of loose ends now
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
      Might as well unplug the O2 so it goes into open loop.
      Pull the fuel pump relay and crank it in 5 second intervals a couple times to build oil pressure.
      Check your fuel lines, check your fluids and you should be good to go afer that.
      Once it's running grab a flashlight, look for leaks or smoke. And listen to weird noises. If it doesn't blow up in the first 20 seconds, you're good.
      1985 325e 2.8 Turbo VEMS
        Don't get too excited and leave it running in first gear and try to get out of the car without putting it in neutral, garage doors go down like crazy doing that.
          Speaking from experience are we?
          '89 Alpine S52 with goodies
            NAH, just start it, get in ,and drive ....lol
            NASA
            BMWCCA member
            PCA member 25yrs
            1997 M3 sedan
            2001 325CI DD
