m50 plus s50 cams
  • Jchayward90
    • Jan 2010
    • 12
    m50 plus s50 cams
    Hey guys just putting together my m50 and have read of upgrading to the m3 cams will give a significant power increase. I know you need a custom chip but is there anything else it would require and would a set be worth $325? Thanks 4 ne input
  • Uber E30
    • 1409
    Just the chip and trays, and that price is about average depending on condition. S5x cams run anywhere from 250-350.
    -Alex
    • e30s50dan
      • Nov 2008
      • 2076
      dont forget the cam tools...couple i bought cost $160...well worth it imo
      NASA
      BMWCCA member
      PCA member 25yrs
      1991 318IS slick top
      1997 M3 sedan
      2001 325CI DD
      “whoever turns the wheel the least, wins"
      • matt
        • 3732
        You don't need to swap trays to put S50 cams into an M50TU.
        You do need to swap trays to put S52 cams into an M50TU.
        • e30s50dan
          • Nov 2008
          • 2076
          ^^ right.... you will use your m50 lifters with m50 trays
          NASA
          BMWCCA member
          PCA member 25yrs
          1997 M3 sedan
          2001 325CI DD
          • Wishno87
            • 6025
            Is there a performance advantage to using the s52 cams over the s50 cams or are the profiles the same?
            • White325is
              • Oct 2006
              • 5947
              I ran S52 cams, pink top injectors, 3.5 maf and a TMS chip in my old M50 swapped e30.
              That thing was a blast.
              • mazur
                • Jan 2006
                • 731
                Some say the S50 cams are "hotter", but I'm sure they're the same.
                • kevnj
                  • 92
                  What's involved in swapping the cam trays from a vanos motor to a non vanos motor? Is this something that needs to be done by a machine shop?
                  • 10Toes
                    Me Father Was A Tree
                    • Jan 2008
                    • 61222
                    They just come out when the cams are unbolted, no machine shop needed.
                    • kevnj
                      • 92
                      Thanks. Makes sense.
                      • gregslow318i
                        • Sep 2007
                        • 1918
                        umm you cant run vanos cams on a non-vanos motor unless you convert the whole system on to the motor....dme, harness, vanos unit, oil filter housing, valve cover + more ....ect
                        looking for a e30m50 swap harness adapter pm me $150 shipped
                        email nitroman12@gmail.com
                        • darrenforeal
                          • 219
                          May want to consider pink top injectors when doing this and obviously the Turner chip. Also make sure your VANOS is in good shape, as you have to take it out anyways. I am doing this right now in my E34. You can also rent the tools from Dr. VANOS.
                          Team Hybrids
                          • JJe30
                            • 2044
                            When I put in my s50 cams I also did pink top (21.5lbs) injectors and 540i MAF (3.5") with chip.
