CEL 1226 knock sensor
  • e30s50dan
    • Nov 2008
    • 2076
    Ok just finishing up loose ends on the swap. CEL is NOT on but i am getting 1226 code knock sensor. I'm sure they are not backwards and both are fairly new. I am driving around with hood off for now and don't hear any pinging. Car runs great,thanks to Matt for awesome software question is it possible that I may have torgued them on to tight?? Why the code. Tia. Dan
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
  • atldohc
    • Nov 2008
    • 359
    obd 1 swap? if it is i would suggest swapping the knock sensors. clear the codes, test drive and check codes again. if the troublecode is for the other knock sensor this time you know that sensor is faulty
    • e30s50dan
      • Nov 2008
      • 2076
      found trouble..bad ECU! thx
      NASA
      BMWCCA member
      PCA member 25yrs
      1997 M3 sedan
      2001 325CI DD
