quick engine check
  • R&D man
    • 79
    quick engine check
    How can you tell the difference from a m50 and a m52 engine >?
  • FredK
    • 14764
    Do you suspect the M52 been converted to OBD-I / 413 DME?
    • etxxz
      • Feb 2006
      • 2085
      location of oil cap on the valve cover. if in the back. m50. if towards front (towards vanos) m52. that's the easiest (visible that is) way.
      No more e30s for me.
      88 black BMW OBDII 332is dedicated track [sold]
      88 BMW OBDII bronzit 332is [RIP 03/08]
      91 BMW 325i [sold]
      86 Corolla 'Ae86' HB 20v trd [sold]
      http://youtube.com/watch?v=pTj7Hn9v5Rs
      • R&D man
        • 79
        difference
        The engine i bought had 320i in yellow paint in the plastic valve cover .I am trying to find out which cam sensor to get The old one has the end cut off and the wires inside were all cracked.The end of the sendor plug would not match the engine harness plug.I thought also the valve cover could have been from another car........I found out why it wouldnt crank yesterday.the orca cd said not to hook up the unloader relay wire .I could not see the other point were the wire went until I removed the starter.The manual picture is poor.I hooked up the wire and all the electrons went where they were supposed to.I feel dumb know...I guess I am in a hurry to get it done being it is my daily driver and borrowing my wifes car.
        • etxxz
          • Feb 2006
          • 2085
          m/s50's have the crank sensor... at the crank. m/s52's have them at the rear of the block even though they also have the "bracket" for the crank sensor at the front (used by OBD1 conversions)...
          91 BMW 325i [sold]
          • e30s52
            • Oct 2007
            • 5235
            Look at the engine tags.
            www.gutenparts.com
              • 37834
              VIN number always works too.
              Grover Beach, California
              BimmerHeads.com
