I know I have seen these answers somewhere but I have been searching on and off the last few days and i cant for the life of me find the answers again. I just bought a M20B23 ltw flywheel a few days ago and im not sure which TO bearing I need to get for my M50 and G260. I have seen guys talking about using the 323 TO bearing for their M20B25 flywheels and G260s but what about if im using a 323 flywheel? Also I have a single mass eta clutch disc and PP that are almost new that I would like to use. Would that be a problem? Thanks in advance gentlemen.
Noob M20B23 flywheel questions
I am using that flywheel in my m20b25. It uses a regular TO bearing, same one that comes stock on 325i. If you check real OEM, the PN's are the same.
If you are using a single mass FW, you need a single mass clutch,PP, and TO bearing.
ETA's I believe all came with dual mass, so I dunno how you got a single mass ETA setup.
Also, I think if you are using the 323 FW, you also will need to use the starter from a 325i on your m/sx..unless they are the same.
Basically the starter, FW, clutch, PP and TO bearing all need to be from the same car.
Cant mix and match dual mass stuff with single mass, the thicknesses are wrong.
Thanks for the responses guys. I think someone had converted my eta to a single mass flywheel. It still has the reference pins too. So then i should be able to use my single mass clutch kit off the eta then right? I think i have a b25 TO bearing somewhere too.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by Wishno87 View PostThanks for the responses guys. I think someone had converted my eta to a single mass flywheel. It still has the reference pins too. So then i should be able to use my single mass clutch kit off the eta then right? I think i have a b25 TO bearing somewhere too.
I may still have the single mass T/O bearing I pulled from my car when I replaced everything if you need it. But they are cheap, which is the reason I replaced mine while I was in there.
Originally posted by blocke View PostETA's I believe all came with dual mass, so I dunno how you got a single mass ETA setup.
I starter with single mass, would be nice to have the matching starter for flywheel but the thing is ancient so an i will do.
