Bad dme?
  • sushipower
    • Aug 2005
    • 156
    Bad dme?
    If your engine light does not light up when you turn on the key, does this mean your DME is bad? Also, tried using the bavauto scan tool and it's throwing a E10 (cannot comunicate with DME).
    Thanks in advance.
  • matt
    • 3731
    You might have your chip in backwards.
    • sushipower
      • Aug 2005
      • 156
      Haha you're probably right. I'll check
      • sushipower
        • Aug 2005
        • 156
        Need to add... Long story short... car was running perfect, then tried to installed porsche MAF and then i fried my wires to MAF, re-wired it and now car won't start. I purchased a 413 DME and hope that's the problem. I'll post results later.
        Thanks
        • Nick325is
          • 1409
          Thanks in advance.
          I made this same mistake the first time. Turned the chip around and life was good.
          • matt
            • 3731
            Thanks
            Did you change your chip also?
            If you are not getting a CEL, you either have no chip or a backwards chip, or you have a bad DME. Or it's a wiring issue.
            • e30s50dan
              • Nov 2008
              • 2076
              Had a bad ecu crazzzy thing happened with mine. Would run. No tach. All service green lights on and was throwing a bad knock sensor cel Changed out ecu and all is good. Thank Matt. Luv the S50 chip
              NASA
              BMWCCA member
              PCA member 25yrs
              1991 318IS slick top
              1997 M3 sedan
              2001 325CI DD
              “whoever turns the wheel the least, wins"
              • matt
                • 3731
                No problem, Dan. Glad you like it.
                • sushipower
                  • Aug 2005
                  • 156
                  Turned chip around and still no luck. If I recall the notch on the chip indicates pin 1 at the bottom. haha, well I guess i'll just wait for a replacement DME to find out.
                  Thanks guys, I'll let you know what happend.
                  • sushipower
                    • Aug 2005
                    • 156
                    Just wanted to reiterate… when I turn the key to on position but short of cranking engine, my “Check Engine” light does not light up. This is why I think I fried my DME. What do you guys think?
                    • Danny
                      • 14217
                      Main relay.
                      • F34R
                        sLaughter
                        • 12390
                        ^ 1+ had the same thing happen when my main went. And if you fried it then you might have done in the main relay too. FYI first relay, should be white.
                        Instagram: @BWeissLeather
                        Current cars:
                        ~ '87 325 M30B35 swap
                        ~ '87 535
                        ~ 01 540 Msport 6spd
                        ~ '06 X5 4.8is
                        • trackjunkie21
                          • Jan 2010
                          • 3962
                          I fried my DME and I still had a check engine light displayed. Check your main relay or any other relay next to it. I remember if I was missing atleast one of those relays, the check engine light would dissapear.
                          Originally posted by Wh33lhop
                          VANOS: sometimes you just need to go full retard.
                          • sushipower
                            • Aug 2005
                            • 156
                            Okay after several hours, still no luck. here are results of my test.
                            1. Engine will crank
                            2. No fuel pressure
                            3. Instrument panel, head lights, brake, horn, radio… all working normal
                            4. 3 main relays click when remote 12v is applied, but not when relay is in socket and key is turned on.
                            5. I tapped into engine wiring harness on the firewall (red wire), no voltage, even when key is on.
                            6. Changed DME (red 413), still no results.
                            What would prevent voltage to the engine wiring harness and is there a main fuse somewhere?
                            Any suggestions??
                            Thanks in advance…
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              Well there is the fusible link in the trunk...
                              '89 Alpine S52 with goodies
