surging idle
  • R&D man
    • 79
    surging idle
    I now have a surging idle .Th car starts fine whe it is cold.....after a few minutes it starts to surge from 500 to 1200 rpm .the car is a m50 transplanted in a e30.
    I replace the idle control vale and it seems to still do it.I had the idle set perfect after it warmed up but now this morning it is back surging ...Any thoughts
    Thanks
  • 7pilot
    • 475
    Air leak between the MAF and the intake ports.
    m
    • nrubenstein
      • 3148
      Yes, a vacuum leak is likely. Also pull codes and see if there are any other issues - like, say, knock sensors.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • R&D man
        • 79
        codes
        I have no way of pulling codes I have the early 1986 instrument cluster as well no stmp test.
        • Adrian_Visser
          • Jun 2006
          • 2823
          I you wired power to pin 16 of the diagnostic connector you could hook up a peake scanner to it and pull the codes that way.
          '89 Alpine S52 with goodies
