Hey R3V. What should I do?
  • Wishno87
    • 6025
    So I was swapping oil pans from my NVM50B25 to my M50B25TU and I noticed something unexpected.
    My oil pan has this here.
    But my block has this here.
    Because my oil pan did not have it here.
    Is this important? What should Wishno87 do?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Take the one off the block.
    • Wishno87
      • 6025
      Does it simply bolt in? Is there anything else that will come loose when I remove it? Like something relating to the rotating assembly?
      • Van Westervelt
        • 9365
        You are fine. Just remove the bolts off the one on the block. You have it on a stand, so flip it over and use your pepperoni arms for good measure! lol jk jk But you are fine taking it off, just be sure you put those bolts back. ;)
        • FredK
          • 14761
          Nope, it's just secured there with a few M6 bolts, and has zero to do with the rotating assembly.
          • Wishno87
            • 6025
            The bolts for the tray thing? Cant I just leave them out if Im taking the tray off?
            • blackhawkimpact
              • 2415
              You can leave them off
              • Wishno87
                • 6025
                Are there TQ specs for the M50 pan gasket like there are with the M20 cork pan gasket?
                • mazur
                  • Jan 2006
                  • 731
                  Torque spec is 7 pound feet for 8.8 grade bolts and 9 pound feet for 10.9 grade, which is damn low. For all small hardware (and relatively meaningless), I just tighten until it feels tight without going overboard. Never had problems doing it that way.
                  • StereoInstaller1
                    GAS
                    • 22679
                    tORQUE SPEC IZ LIEK 200000 INCH/FEET SO CRANK DAT BISH TILL IT STRIPZ
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • Wishno87
                      • 6025
                      Alright cool. I took the tray off the block and Im off to install my oil pan :-D
                      • Wishno87
                        • 6025
                        It turns out the passenger side of the tray contacts the area where the holes were for the old tray so I need to cut those areas of the tray off. The scalloped area shown below.
                        • 7pilot
                          • 475
                          Hammer.:D
                          m
                          • madjurgen
                            • May 2005
                            • 1203
                            Is this an either-or situation? My e34 m50 pan doesnt have the baffle and my block didnt come with the windage tray. The baffle looks like its riveted into the pan, therefore my only option is to run the windage tray. Does it fit with the e34 m50 pan?
                            Someone want to sell me their extra windage tray?
                            As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                            You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                            • Wishno87
                              • 6025
                              What year is your engine? My 92 NV does not have holes in the block for the tray.
