My first rebuild - S50
  • graphikg
    • Jan 2008
    • 1614
    I decided to rebild my engine because it was making a sound that sounded like bent valves. 3 different BMW techs told me it was bent valves, but after taking the head off, the machine shop told me that there was no problem with the head or valves. So I got it machined anyway.
    Looks like a mirror - ooohhhhh
    Aaaaaaahhhh
    The shop didnt label the trays though - so I dont know which one is exhaust or intake
    OR
    But I am guessing by the "E" it means exhaust
    I am going to replace 1 woodruff key - not both because I have to remove the oil pan and lift the engine and take off the mounts for that.
    My old woodruff key looked like this after using pliers to take it out - so I think the gear woodruff key should be okay.
    Might supercharge in the future - so I am putting these in.
    Supposedly our engines can make up to 500hp on stock heads. But I am gonna put in nice headbolts anyway.
    Nothing special like a turbo build. But it is my first rebuild, so I putting it out there.
  • FredK
    • 14764
    E actually is for something like Einlass (inlet)
    A is for Auspuff, exhaust
    Look at the cam caps, they're also identified with a letter / number combo describing which side it's supposed to be on, as well as the position (1-7, 1 being at the front of the engine).
    • psyber_0ptix
      • 904
      Einlass bedeutet "intake" auf Englisch
      edit: Fred beat me to it
      Originally posted by FredK
      However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
      My year in Germany
      Feedback
      • dsobering47
        • Oct 2007
        • 697
        Newer motors have "Ein" and "Aus" on the VANOS/camshafts as well. Easy way to remember is just to say them aloud (Ein sounds like IN, while Aus sounds like OUT)
        Just to re-iterate something for the 3rd time.
        • mazur
          • Jan 2006
          • 731
          Hey, your aluminum heading is rusting ;)
          • e30s50dan
            • Nov 2008
            • 2076
            Don't forget the little oil check valve thingy on the bottom. It screws in. I replaced mine. $20 from BMW.
            NASA
            BMWCCA member
            PCA member 25yrs
            1991 318IS slick top
            1997 M3 sedan
            2001 325CI DD
            “whoever turns the wheel the least, wins"
            • etxxz
              • Feb 2006
              • 2085
              my key fell off too last time i rebuilt it (but not the first time) so i freaked out when my crank pulley didnt "lock" i was like wtf i can't time my engine looked on real oem and saw the piece separated. I found it like 3days later... what a total newb i am
              what is the function of this valve? i couldn't figure it out.
              No more e30s for me.
              88 black BMW OBDII 332is dedicated track [sold]
              88 BMW OBDII bronzit 332is [RIP 03/08]
              91 BMW 325i [sold]
              86 Corolla 'Ae86' HB 20v trd [sold]
              http://youtube.com/watch?v=pTj7Hn9v5Rs
