Wire Identification
  • PiercedE30
    • Apr 2005
    • 4220
    Wire Identification
    I have no clue what these wires go to. The plug was cut off when I got the harness. I think it might go to the transmission since it was from an auto car. Any help identifying what these two wires go to would be greatly appreciated.
    One is brown (figure it is a ground) while the other is white/blue.
    My 2.9L Build!
  • e30s50dan
    • Nov 2008
    • 2076
    Where is it on the harness. Is it on the long end like it would go to the tranny or closer to the top. May be reverse Not sure. Someone will chime in
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
    • PiercedE30
      • Apr 2005
      • 4220
      It's in the same bundle of wires that go up under the intake manifold. I'm pretty sure it goes back under the car just like the O2 sensor because the O2 sensor wire is also cut.
      My 2.9L Build!
      • blackhawkimpact
        • 2415
        You need to post a better/bigger pic to see were it's coming from the harness.
        • 7pilot
          • 475
          In my notes, I have this as oil level sender wire that goes to the sender at the bottom of the oil pan on an E34.
          m
          • herlsy
            • Sep 2009
            • 339
            m
            Oil Level sender should have 3 wires coming off it, i think the other color is blue/yellow if i remember correct.
            If you have everything already connected, determine by process of elimination.
            If you don't have everything connected already, find out what each connector is on the harness.
            Should have:
            Engine Coolant Temp
            Coolant Gauge
            Crank position Sensor
            Cam position Sensor
            Intake Control Valve
            Intake Air Temp
            Throttle Position Sensor
            O2 Sensor
            MAF Plug
            Emissions Purge Valve
            There could be more, i'm going by my NV harness...feel free to add r3vers
            • 7pilot
              • 475
              ^^^ You're correct I 2xchecked.
              m
