i have a leak
  • M-technik-3
    • 18946
    If your gonna buy a heater core buy a new one! Used is not worth the hassle.
    • Gnarles
      • Dec 2008
      • 342
      I meant buy the valve used. Definitely buy a new heater core!
      • Danny
        • 14216
        Wait. So I have to take out the dash and all that bullshit to replade this little god damned valve?
        • StereoInstaller1
          GAS
          • 22679
          NO! Just pull the seat out so you can get your scraggly ass in there easier
          Closing SOON!
          Thanks for 10 years of fun!
          • Gnarles
            • Dec 2008
            • 342
            you can get to it without pulling the dash.
            check this out:
            • Danny
              • 14216
              What would happen if I just replaced the valve with a straight piece of pipe? I have no ac so it wouldn't matter to me if my heat was on all he time. I always just shut all the vents anyway and have the windows down when its hot. Thoughts?
              • FredK
                • 14764
                That is more trouble than it's worth, because the valve is held in place by a triangular flange, and is made watertight with an o-ring. You'd have to do some real hacking to get things to be watertight with a bypass pipe. You can usually get a used valve for like $20. Get a used valve.
                • Danny
                  • 14216
                  When I get home I'm gonna throw some rtv around the part that's leaking and see if that helps for now, if not, oh well.
                  • Atreus
                    • 1846
                    just pull out your driver seat and get to work... those little screws/bolts are the worst.... have fun with that, make sure you have some towels ready too.
                    1991 325iC - Mauritsblau sumthin metallic blue. DEAD
                    1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
                    1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
                    1991 325iC - Calypsorot Metallic
                    1994 540i - Granitsilber
                    Originally posted by scabzzzz
                    I've had blunts cock in my mouth, but I'm not gay.
                    • Danny
                      • 14216
                      If the magic of rtv doesn't fix it, I'll snag the part off ebay.
                      • jrdeamicis
                        • Nov 2008
                        • 956
                        Ill just give you mine.. Come grab it @ my place in SF
                        Past Car : E30 S50 6 Speed 5 Lug 3.73
                        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                        ___________________________________________
                        BNB Designs
                        Engine Swaps, Fabrication, Innovation, General Repair
                        Richmond CA
                        Julian 848-248-8029
                        • Danny
                          • 14216
                          Okay when are you free?
                          • jrdeamicis
                            • Nov 2008
                            • 956
                            A lot..... Tomorrow works well. All day.
                            BNB Designs
                            Richmond CA
                            Julian 848-248-8029
                            • Danny
                              • 14216
                              PM'd
                              • genocide98
                                • Oct 2009
                                • 106
                                RTV or silicone wont hold, I've tried it.
                                I ended up pulling the entire solenoid out and making a plastic plate to keep it open 24/7 because I didn't have $200 and I couldn't find a good one in the parts yard. It sucked having the heater on 100% the whole time, but my AC didn't work anyway.
                                You don't have to remove the dash, just the center console and knee bolster/kick panel. Pulling the drivers seat makes it easier, and having a few towels on hand to catch or mop up the water that will undoubtedly come from the heater control and core.
                                I recommend backflushing the cooling system or replacing the heater core while you're at it.
