alright car will die and not start for awhille
  • ReSoP
    • Dec 2008
    • 148
    well for awhile ive been having this problem after alittle of driving my car will just die no sputtering or anything. and then wont start for alittle while.
    so far ive replaced the crank position sensor, cam position sensor, injectors, traced the grounds on the injector harness and engine mount to the frame and coil ground. I need some advice on what this could be. Not giving and cel or warnings.
  • Schwarz325
    • Aug 2009
    • 487
    Sounds like either your fuel pump relay, or starter.
    i say start with the fuel pump and ecu relays, they're relatively cheap at the dealer. and cheaper than a starter that's for damn sure
    • StereoInstaller1
      GAS
      • 22679
      Most likely a main relay, those are the exact symptoms.
      What does your tach do when this happens?
      Closing SOON!
      Thanks for 10 years of fun!
      • ReSoP
        • Dec 2008
        • 148
        sorry forgot to mention Ive already replaced the fuel pump and relays. I replaced one ecu relay unless theres a different one. And for the tach it just falls dead and does nothing.
        • Schwarz325
          • Aug 2009
          • 487
          Have you replaced the main relay, like stereoinstaller mentioned?
          • StereoInstaller1
            GAS
            • 22679
            The main is the only relay that works, even though others fit.
            Closing SOON!
            • Adrian_Visser
              • Jun 2006
              • 2823
              Main relay = DME relay = ecu relay.
              '89 Alpine S52 with goodies
              • ReSoP
                • Dec 2008
                • 148
                ok well How do you check if the relays are getting power I just put a ohm meter with the black on the shocktower and the red i moved to each terminal. And well None are giving any volts, which then I checked the fuel pump maybe to see if Im retarded when checking for power on the relay sockets. Fuel pump has no power. And unhooked my adapter and only pin 21 has power?? I bought the adapter through akg.
                • StereoInstaller1
                  GAS
                  • 22679
                  Wait: NONE of the pins on the main relay have power?
                  Check your ground, and buy a testlight. DMMs are great for lots of stuff, but they suck for this stuff.
                  Closing SOON!
                  • ReSoP
                    • Dec 2008
                    • 148
                    Nope not a single pin is getting power. It seems like the only thing getting power in the engine bay is the starter. I have a test light. Sorry dmm?
                    • StereoInstaller1
                      GAS
                      • 22679
                      OK: DMM is "Digital MultiMeter"
                      So, reading the diagram shows the red wire on pin 30 of the main relay gets +12V from the battery junction block.
                      Make it so.
                      Closing SOON!
                      • MR E30 325is
                        • Dec 2008
                        • 3300
                        What is your swap? did you convert from OBDII to OBDI and keep the OBDII coolant temp sensor?
                        If this is not the case, continue to listen to stereoinstaller.
                        My previous build (currently E30-less)
                        http://www.r3vlimited.com/board/showthread.php?t=170390
                        A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                        • ReSoP
                          • Dec 2008
                          • 148
                          well finally figured out my problem turns out the power cable the smaller one that runs from the battery to a small post on the power block. Well where it connects to the battery had corroded i guess from all the years and was only hanging on by a few small strands. Replaced the wire and no problems. Thanks stereoinstaller it was the information about pin 30 that help me figure this out.
