How to get off the torque converter?
  • glucklich21
    • 1912
    So I pulled my NV M50 out of my E34 donor car a while back. Well I finally took off the cancer that was attached to my engine, aka the auto trans. Only problem now is I have no clue how to get the torque converter off. I can see the 3 bolts that look like they hold them on, but I have no clue how to get at them. Any ideas?
  • herlsy
    • Sep 2009
    • 339
    Look under the oil pan where it bolts to the transmission. There should be a hole, possibly filled with a rubber plug.
    Rotate the crank until you see a bolt in the hole, then loosen it. There should be three bolts holding it there, once the three bolts are gone it should drop off.
    • glucklich21
      • 1912
      Thanks. Dunno why I didn't think of this sooner, I just undid some bolts I had keeping that metal plate in place and unbolting those 3 was much easier. ;)
