S50 wierd noise. Help Diagnose (vid)
  • xwill112x
    • Jan 2009
    • 4236
    it can run but its probably scarring your cams.
    • e30s50dan
      • Nov 2008
      • 2076
      some of that noise is normal..ie injectors/lifters...but sound like a noisey vanos or gears...im on board with ed94r
      NASA
      BMWCCA member
      PCA member 25yrs
      1991 318IS slick top
      1997 M3 sedan
      2001 325CI DD
      “whoever turns the wheel the least, wins"
      • graphikg
        • Jan 2008
        • 1614
        Update... After running the car a little more, it has been a little quiter. It still runs like crap and is shaking all over the place; i.e. when I am sitting in the car, I can see my passenger seat ocillating from side to side. This is leading me to think that it is bad timing.
        Also, my car looks like this
        I have the thrust washers shown as well as the spring plate. So I think I have the later style with the longer bolts.
        I wish one of you could ride in my car and feel how it shakes and sounds like a monster truck when going up to 3-3.5k rpm.
        • ed94r
          • Mar 2004
          • 382
          That's the later set-up. If you have this arrangement, then I'm out. Good luck tho.
          For shit's and giggles, what codes are being thrown?
          Ed
          1988 E30/S50...now with S52; Track
          1994 Miata R; ES Solo2
          1998 Lexus LX470; Wife (Slee'd anyway)
          2002 BMW 530i; A+ Commuter
          2002 BMW 325iT; Sport/Premium 5-speed
          2011 21' EconoTrailer
          • Danny
            • 14216
            Did you tighten your spark plugs?
            • graphikg
              • Jan 2008
              • 1614
              Spark plugs are tightened just fine I reckon.
              Thanks for the input though Ed.
              • dude8383
                • Jan 2005
                • 10387
                Listen to the man! He helped me out with my dilemma not too long ago :up:
                Wouldn't hurt to check you know?
                • Danny
                  • 14216
                  cuz mine did the same kinda noise, my spark plugs were finger tight.
                  • graphikg
                    • Jan 2008
                    • 1614
                    Ed
                    I dont think I am even getting any codes.
                    • BMW_TUNER
                      • Jul 2006
                      • 1386
                      You need to check each lifter to be sure that it is easily compressing and that it can draw fluid. If it can not you can remove the piston( gently) and clean the inner bore as well as sand the piston with 2000 grit. I did this on some of my sticky ones prior to reassembly. They now pump up and hold pressure perfectly. I had a link to a euro forum in the uk where the guy did a full write up. I am still looking for it. The only other thing that I have heard of happening is that the lifter gets destroyed in over rev situations because it pushed all of the fluid out and them bang the piston into the wall thus killin the lifter.
                      1989 332IS -S-Fiddy Four-Some weight removed.
                      5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
                      • graphikg
                        • Jan 2008
                        • 1614
                        If one (or more) of my lifter(s) is killed, would my car run like crap? Shaking and rumbling to where you can feel the vibrations in the cabin?
                        • BMW_TUNER
                          • Jul 2006
                          • 1386
                          It should but the lifter could be locked all the way up or in the middle so who knows. The valve train just sounds far to noisy to be healthy.
                          • the fil
                            • Aug 2007
                            • 237
                            PM DiscoTechnix or something like that on bfc. He had a diesel sounding motor, I can't remember what it was though but I think it was something in the head that was fucked pretty good.
                            • BMW_TUNER
                              • Jul 2006
                              • 1386
                              It could be that the timing is way off too and it is dieseling.
                              • nrubenstein
                                • 3148
                                I can't watch the video where I am, but can you describe how the engine is running? Have you confirmed that all cylinders are firing? (The best way to tell is by taking temperature readings off the individual exhaust tubes.)
                                2002 BMW M3 Alpinweiß/Black
                                1999 323i GTS2 Alpinweiß
                                1995 M3 Dakargelb/Black
                                - S50B32/S6S420G/3.91
                                1990 325is Brilliantrot/Tan
                                1989 M3 Alpinweiß/Black
