Recently I have been trying to find out why my car is shaking in the cabin between 1000-1800. After reading and searching... I am starting to bet that my clutch/Pressure Plate is done for. To find out for sure, I jacked the car up on the front and held the revs at around 1500 rpm. I got under the car and noticed that my bell housing is shaking a bit. It doesnt seem like too violent of a shake, but maybe it is more than it should.
When I put the car down, I was reversing it into the garage and made a wierd dicovery. With the shifter in gear (reverse or 1st), and the clutch pushed all the way to the ground, I noticed that the car would move in accordance to what gear I was in when I revved to 3500-4300 rpm. It doesnt move drastically, just slightly.
This tells me that the clutch is slightly engaging the flywheel even when it is supposed to be disengaged. The question is why? and could that also be causing my vibration in the cabin? Does my pressure plate/ clutch need replacement?
