E21 m50 swap not running good
  • jeds320i
    • Sep 2009
    • 54
    i swapped in a nonvanos m50 into my e21, and i finally got it to the shop to get exhaust put on it and drove it back home today. when my car was open headers, it ran rough at idle and low rpm bc the 02 sensor wasnt hooked up. so i thought thats why it ran rough. well after i got exhaust put on and the 02 sensor hooked up and everything, it still ran the same. it sounds like its cammed at idle(which it isnt cammed) and low rpm driving in like 1st-2nd barely on the throttle its jerky and like up and down rpms like.. it doesnt run smooth like it should. i thought for sure when i got exhaust and hooked up the 02 it would totally fix the problem and run smooth. i thought running no 02 wood make the computer go into a slight limp mode or something and make it run rich and rough. does maybe a code need to be cleared or something? i dont think its running to its full potential even tho the car is pretty quick past 2k rpms. any suggestions? ill post up a vid tomaro
  • MattM
    • Apr 2009
    • 931
    vacuum leaks
    Full Build Thread Here
    • Edev
      • 3731
      Originally posted by MattM
      vacuum leaks
      This.
      I had one, and it was from under the throttle body. There are three nipples (ROOOOFLLL) under there, and for my swap, I plugged the far right (closest to the firewall), and the middle one. It fixed it.
      M Coupe
      • Voluted
        • 104
        AFM backwards?
        • jeds320i
          • Sep 2009
          • 54
          the maf i not backwards, i guess it could be a vac leak but it just doesent seem like it wood be that.. what all hoses should i check and stuff?
          • Adrian_Visser
            • Jun 2006
            • 2823
            All of them. As in every hose going to the intake manifold. First just try disconnecting your battery for 15 minutes to reset the DME it may still be compensating for the O2 sensor and open headers.
            '89 Alpine S52 with goodies
            • jeds320i
              • Sep 2009
              • 54
              ok i disconnected my battery for well over 15 minutes and that didnt help anything, i checked all of the vacuum lines, put clamps on most of them and even used high temp silicone on the joints for most of them.. condition still persists.. the only hose i couldnt really get to was the icv ones.. but i looked at em and kinda felt em and they seemed fine.. any suggestions?
              • jeds320i
                • Sep 2009
                • 54
                ^my car sounds exactly like this, and the guy who made the vid said the hose going to the intake and icv was bad so i assume thats my problem.. so i ordered two new hoses and the connector that plugs into the intake i hope this fixes the problem.
                • justin_l_
                  • Jun 2007
                  • 1079
                  Take some carb cleaner and spray around hoses. You will get a change in idle if you spray over an vaccum leak. Never good to just throw parts at it.
                  • LivingLegend06
                    • Dec 2006
                    • 1604
                    Originally posted by jeds320i
                    http://www.youtube.com/watch?v=WVbNG...layer_embedded
                    MY NVM50 sounds like that too, but I still have a lot of things to fix before I get to the idle.
                    • jeds320i
                      • Sep 2009
                      • 54
                      ok dudes, i replaced all the icv hoses and stuff including the plastic intake connector thing. it still runs the same.. i reset the ecu and everything... SUGGESTIONS!
                      heres a vid:
                      • fiftytakedowns
                        • 2460
                        you must have done it wrong
                        [/url]
                        Team USA Wrestling 67KG
                        • jeds320i
                          • Sep 2009
                          • 54
                          i didnt do it wrong, i replaced the hoses the right way for sure and used clamps.. everythings nice and tight :/ could maybe my icv be the problem or something?
                          • jeds320i
                            • Sep 2009
                            • 54
                            bump! my car still doesnt run right and the new vac hoses didnt fix the problem.. i sprayed carb cleaner around all the hoses and nothing happened so im leaning away from a vacuum leak. i pulled off the ignition coils one by one while it was idling and they all had the same effect, so i think the coils are good. what else could it be?
                            • Aatos
                              • Mar 2008
                              • 43
                              is there any difference on the idling with maf disconnected?
