95 s50 into 89 325i
no fuel or spark. DME relay is not engaging, if I jumper the relay I get the ICV hum, fuel prime, check engine light at ACC key position. Otherwise I get none of that.
I either have to jumper the relay or manually ground it out. The DME is not sending a signal to close the ground circuit (I believe pin 27 on DME).
I do have continuity from pin27 to the relay socket.
I'm assuming my DME is toast? or am I missing something?
