M50 vs S50
  • e46s54dr
    • May 2008
    • 1059
    M50 vs S50
    I tried searching but couldn't find a definite answer. How can you identify a s50 from an m50? I'm about to purchase a s50 engine and I'm wondering is there anyway to identify it other than the mpower valve cover. Thanks in advance. -David
  • Danny
    • 14216
    The vin stamped on the block
    • e46s54dr
      • May 2008
      • 1059
      Is there a certain set of numbers or letters that will let me know it's a s50 or would I have to run the serial numbers by the dealer?
      • gregslow318i
        • Sep 2007
        • 1918
        should have a 30 stamped on the block in the casting plate
        looking for a e30m50 swap harness adapter pm me $150 shipped
        email nitroman12@gmail.com
        • e46s54dr
          • May 2008
          • 1059
          thanks guys, I'll keep my eye out for that!
          • matt
            • 3732
            No such thing.
            You can look for the 30 on the block, or there might be a VIN sticker on the back of the cylinder head. If it start with WBS it's an M car, if it starts with WBA it's a regular BMW.
            • ethirtydavid
              • Jan 2008
              • 2331
              There will be a VIN number on a thin metal plate on transmission side of engine in the back on the head. This can go missing though-
              One other sure place to find true identification is found on the block right by the driver side engine mount arm (firewall side).
              -Read that number to BMW dealership and they will be able to identify the engine
              • DesertBMW
                • Aug 2011
                • 1037
                Under the serial number there is a engine code:
                30 6 S1 (is 1995 3.0L M3 engine)
                25 6 S1 (is 2.5L M50 engine)
                32 6 S1 (is S52 engine)
                28 6 S1 (is 2.8L M52 engine)
                25 6 S2 (is 2.8L M52 aluminum block engine)
                30 6 S3 (is 3.0L M54 aluminum block engine)
                • justin_l_
                  • Jun 2007
                  • 1079
