And obviously, I plan on doing an OBD-II S52 swap. The general idea is raceland headers, m50 exhaust, tune from TRM who will also delete the emissions stuff (rear o2 sensors, secondary air pump) and EWS.
I've been researching for what seems like months because I've been passively looking for an S52. This car basically dropped into my lap two weeks ago, so I jumped at the opportunity. Fast forward to this past weekend (which luckily was my fall break) where I ripped out the engine and trans and stripped the car.
I took all the obvious items I'm going to need from the car, but I'm wondering if I'm missing anything. I took the entire engine wiring harness and plan on making an adapter to hook up to my c101. Do I need any of the body wiring? What about the three connectors in the engine bay and the associated wiring? I snapped a quick picture, but it's pretty much mayhem:
The fuse box was all smashed from the accident so I wasn't sure how to take it all apart. Some of the connectors in that bunch plugged into the A/C compressor and the (I think) secondary air pump. Do I need these?
What about the fuel pressure regulator/purge valve/contraption on the drivers side frame rail? It has what seems to be a vacuum line going to the intake?
I am under the impression an e36 diff has different mounting points and simply swapping the cover does not work. Is this correct? I plan on using the ZF that came with the M3, so I'm looking for a 3.25 or similar ratio LSD, I presume.
I think that's all for now, any help is appreciated. Build thread will come in May when I'm home from school, although I'll probably start resealing the engine and whatnot over my winter break.
