Coolant Expansion Tank
  • Chrisv006
    • 375
    I have a late model expansion tank im trying to install into an early model car but I don't see where it lines up. From all the stickies and searches it sounds like it should just bolt in somewhere.
    Anyone have a decent picture?
  • Beej '86 325es
    • 2639
    You'll need to drill mounting holes for the mounting bracket.
    Just make sure when you install it that the cap isn't so high that it hits the hood.
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
    • Chrisv006
      • 375
      I think that would have worked just fine if I didnt install that damned ABS back in...
      I knew I shouldn't have..Guess Ill have to do something more interesting...
      Thanks
      • Fusion
        • Nov 2009
        • 3659
        You mean this one? Should fit ABS...
        • Chrisv006
          • 375
          Thats the one...
          How is yours attached?
          • Fusion
            • Nov 2009
            • 3659
            Not my photo, but I have the same exp. tank, but switching to M42 rad.
            The expansion tank is held by that brace you can see right next to the ABS (red). On the side of the exp. tank you see those three holes for bolts? you could utilise those to hold it.
            There is also a slide on thingy seen here under the exp. tank:
            Part #10. There is a short threaded rod welded to the body, onto which this plastic part just screws on.
            • Chrisv006
              • 375
              Thanks for the pictures.
              I am going to add a threaded rod so I can use part number 10, looks like the simpler way.
              • e30s50dan
                • Nov 2008
                • 2076
                How about fabbing one up or buy one and put in where the battery goes on the cab's
                NASA
                BMWCCA member
                PCA member 25yrs
                1991 318IS slick top
                1997 M3 sedan
                2001 325CI DD
                “whoever turns the wheel the least, wins"
                • Fusion
                  • Nov 2009
                  • 3659
                  You may also want to weld in a |_______| shape support for that curved bottom holder thing.
