I'm using a ZF trans that came from a 91 525i behind my m50.
For the shifter setup i'm using a 96 328i carrier, selector rod, and shifter.
So the problem is that the shifter carrier sets the shifter a bit too far forward in the chassis opening. It shifts ok but when i add the console, the shifter is hitting it. Shifter sits pefectly level in the carrier as it should.
I've searched around and seen others that have had this issue, but no info on their resolve.
Any thoughts on the e34 ZF310 being different fron the e36 ZF310?
Setup:
m50nv
AKG Motor mounts
e34 ZF310 trans
e21Mounts
1996 328i:
Shifter
Selector
Carrier
Setup:
m50nv
AKG Motor mounts
e34 ZF310 trans
e21Mounts
1996 328i:
Shifter
Selector
Carrier
