E30 M50 oil pan removal.....
  • El Gato Liso
    • Jun 2008
    • 44
    i blew out my oil pan...
    any thoughts of how i can take this oil pan off without pulling the engine?
  • Wishno87
    • 6025
    Pull the tranny and maybe the subframe. I know, it sucks.
    • sharky
      • Jan 2005
      • 2672
      suspend engine, remove engine mount bolts and drop front subframe. Not a fun job but thats how you do it.
      • nrubenstein
        • 3148
        Note that you'll need to pull the trans if you used a G260.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • etxxz
          • Feb 2006
          • 2085
          on a zf, you can get away with just lowering the subframe about 2 inches. i left everything else attached. Does requires you to remove the power steering pump (leave lines attached) and suspend the engine. I put 2" pieces of wood in between the subframe and the car frame to keep it there and the pan came right out. No problem with bolt access... i'm sneaky.
          true... and good luck.
          No more e30s for me.
          88 black BMW OBDII 332is dedicated track [sold]
          88 BMW OBDII bronzit 332is [RIP 03/08]
          91 BMW 325i [sold]
          86 Corolla 'Ae86' HB 20v trd [sold]
          http://youtube.com/watch?v=pTj7Hn9v5Rs
          • DREWHALL
            • Feb 2006
            • 1207
            I've only had the 24v in for a few weeks now, what makes you have to pull the 260 as opposed to the ZF? Just wondering for future reference. I'm not excited to hear this!
            • etxxz
              • Feb 2006
              • 2085
              the oil pan has a few bolts in the back that the G260 won't allow you to reach because of the bellhousing whereas the ZF has very convenient cutouts for it. In other words, the tranny has to come off in order for you to remove the oil pan.
              91 BMW 325i [sold]
              • graphikg
                • Jan 2008
                • 1614
                F! That means I should do my oil pan now since my tranny is out. perfect timing on the thread. Is there a write-up on this?
                • RoadHazard
                  • Sep 2007
                  • 163
                  Drop the subframe. That's how I did mine.
                  Yeah it sucks.
                  90 E30 S50B30
                  http://www.fquick.com/roadhazard/
                  • graphikg
                    • Jan 2008
                    • 1614
                    The subframe consists of just 4 bolts on the chassis right? But dont you have to unbolt the sway bar too?
                    • etxxz
                      • Feb 2006
                      • 2085
                      ^^ it helped, that's for sure.
                      91 BMW 325i [sold]
                      • graphikg
                        • Jan 2008
                        • 1614
                        I dont have a crane to suspend the engine, so I might just have to hold the engine up with jack stands by the enginen mount arms. What a crappy job... But at least my tranny is out already. - do it while you're there.
                        • etxxz
                          • Feb 2006
                          • 2085
                          oh boy am i gonna get flamed. i jacked up the engine and used ratcheting tow straps around a 2x4 (~60" long) that span from fender to fender. It rested on 2x4 bases (~8"long) and they themselves rested on towels. Dropped the subframe, removed my pan. Found out my crank is plausibly bent (type of bearing wear after OPN failure), cyl 4 walls are scratched to hell and out of round, so put the subframe back up and hoisted the motor out this weekend... wish i owned a hoist thankfully i have a lot of motor head friends.
                          -master driveway mechanic
                          91 BMW 325i [sold]
                          • graphikg
                            • Jan 2008
                            • 1614
                            I am doing the job now, and there is no way I am going to do it successfully without suspending the engine correctly. Bottom line is... I need a hoist or this engine will fall on me. I tried using the rafters of the garage, but NOOO WAYY.
                            • DREWHALL
                              • Feb 2006
                              • 1207
                              LOL rafters. Yeah it's nice to have a hoist. Try craigslist a lot of times you can find a used one for less than half the price of a new one that works fine.
