visual differences in 24v engines
  • stinkydriverx
    • Jan 2008
    • 501
    hey guys,
    Whats the easiest way to tell the difference between an s52 and other 24v motors? Besides the obvious valve cover. Any help is always appreciated.
    -Andrew
    Turbo m30 drift car build.
    500whp or bust.
    http://www.r3vlimited.com/board/showthread.php?t=256525
  • gregslow318i
    • Sep 2007
    • 1918
    displacement should be stamped on the block...
    also intake manifolds (obd1 vs 2)
    oil filter housing with/without hard line for coolant
    looking for a e30m50 swap harness adapter pm me $150 shipped
    email nitroman12@gmail.com
    • samiam3356
      • Jul 2009
      • 1901
      3.2 right here
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
      • stinkydriverx
        • Jan 2008
        • 501
        Originally posted by samiam3356
        3.2 right here
        so thats where it should have the number stamped?
        Will it say 3.2 or s52? or a combination?
        500whp or bust.
        • samiam3356
          • Jul 2009
          • 1901
          there will be a lot of #'s but 3.2 should be in there somewhere. There's a thread on here somewhere to decode the rest I believe. Also you could grab the Vin# of the back of the head and run the carfax on it. PM if you get it and I'll do it for free for you.
          $5 shipped?
          • etxxz
            • Feb 2006
            • 2085
            obd1's have the crank sensor on the front and the head has three water ports plugged into it (two temp, one TB coolant) whereas obd2's have the crank sensor in the back (drver's side block by flywheel) and heads have two ports (one temp, one TB coolant).
            Displacement wise, one will be hella fast, the other will be like a sturdy m20 with less ticking. I only know about the tags (visually) You could measure the stroke accurately enough through a spark plug hole (75mm vs ~90mm).
            No more e30s for me.
            88 black BMW OBDII 332is dedicated track [sold]
            88 BMW OBDII bronzit 332is [RIP 03/08]
            91 BMW 325i [sold]
            86 Corolla 'Ae86' HB 20v trd [sold]
            http://youtube.com/watch?v=pTj7Hn9v5Rs
            • rav320uk
              • Jun 2004
              • 1337
              So how do you identify an Alpina E36 M52 3.2 engine as I have the option of buying one.?
              If you have bought items from me, please leave feedback below.
              If you are a BUYER, Check My Feedback.:up:
              http://www.r3vlimited.com/board/showthread.php?t=183860
              Check out my Euro Build Thread
              http://www.r3vlimited.com/board/showthread.php?t=215557
              • StereoInstaller1
                GAS
                • 22679
                Easy to spot gold plating
                Closing SOON!
                Thanks for 10 years of fun!
                • rav320uk
                  • Jun 2004
                  • 1337
                  • StereoInstaller1
                    GAS
                    • 22679
                    Alpina = Gold Plating
                    Closing SOON!
                    • gregslow318i
                      • Sep 2007
                      • 1918
                      I love goooollldddd....
