Difference in Ignition coils?
ODB2's will go onto an OBD1 VC but not vice versa...
Check Us out on Facebook
Full Product Line Tuning
Yes you can basically mix and match whatever...
Bosch is more because it's Bosch. The bremi's are kinda like a no name brand that BMW uses. The work fine. If you look at the part numbers you will notice that BMW has discontinued the Bremi's as well. Bav has the old Bremi's at 44 and change a piece, vs BMA's 52 and change. BMA carries the Bosch ones for 57 each.Last edited by M-technik-3; 11-29-2010, 05:47 AM.
