I have a 91 318is with an obd1 m52.
The cluster is from the 318is and the tach had been working fine until yesterday.
I drove the car for about 20 miles, shut it off, started it back up and have had no tach since.
Ever since i fixed the isssue with the windows, the radio has not been working. I had two connections backwards on the started which caused the windows not to work and the starter solenoid not to engage. After i switched those, starter and windows worked but radio did not.
Also, i have a switched and fused power source to the fuel pump because i had been fighting fuel issues earlier. I had the car running, had good voltage to the pump when the motor was turning. I came back the next day after changing nothing and the pump would not get power.. gave up and ran a switch to it.
Any suggestions on how to fix the problems?
