Problems after chip installed
  • blackhawkimpact
    • 2415
    Just installed my chip for my s50. Everything worked perfect before the chip, 3.5 afm, and injectors were swapped. After the swap, car sounds like shit and turns off. What went wrong?
    I only turned on the car after I installed the chip and it sounded like shit and it turned on. The check engine light also turned on.
  • Dominic49
    • Feb 2007
    • 1373
    what chip were you running before?
    why did you change?
    is the new chip good for the maf? 540 or 996 maf?
    what injectors?
    what is the check engine light for?
    • blackhawkimpact
      • 2415
      Originally posted by Dominic49
      what chip were you running before? TRM chip
      why did you change? 413 DME non-m3
      is the new chip good for the maf? 540 or 996 maf? 540
      what injectors? Pink
      what is the check engine light for? I'll check that in the morning
      Edit: got the codes
      1A Control unit supply
      05 Fuel Injection, Cyl #4
      • matt
        • 3732
        It sounds like your injector connector is not seated properly on cylinder 4.
        • blackhawkimpact
          • 2415
          Already checked and injector 2 was loose. Fixed that and still runs the same. Now I'm getting a Fault code for the crankshaft sensor? WTF??
          • nrubenstein
            • 3148
            Is the DME properly grounded? i.e. bracketed in properly?
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • blackhawkimpact
              • 2415
              That doesn't matter
              • matt
                • 3732
                Originally posted by blackhawkimpact
                That doesn't matter
                Sometimes it does. I've seen it a couple of times.
                Definitely sounds like injector related issues. Are you sure all the electrical connections are getting made?
                • blackhawkimpact
                  • 2415
                  I don't think it does but either way the ecu is mounted.
                  Yeah form were I see it it looks like everything is good. I'll triple check it again
                  • Fusion
                    • Nov 2009
                    • 3659
                    Are you sure all the little prongs on the chip are in place?
                    I'm not sure what would happen if one of them was bent and not in place.
                    • blackhawkimpact
                      • 2415
                      The prongs are in place.
                      • blackhawkimpact
                        • 2415
                        Bump
                        I'm still getting
                        05 fuel injector cyl #4
                        10 crankshaft sensor
                        Now I'm getting 29 (air flow meter)?? What the shit.
                        Will the little green tips on the injectors have anything to do with this? Some of them are broken, only like 2
                        • samiam3356
                          • Jul 2009
                          • 1901
                          You don't have a low battery do you? Was wondering if maybe your not getting enough juice. My dart for the day
                          Originally posted by Roysneon
                          $5 shipped?
                          Originally posted by MarkD
                          You are a strange dude, I'n not answering any more posts from you.
                          • blackhawkimpact
                            • 2415
                            No, the car start fine but it just has a rough idle. I'll try to post a video.
