*Back of the head coolant hose question*
  • samiam3356
    • Jul 2009
    • 1901
    Does it go to the bottom of the heater core or the top? I was under the impression it went to the bottom from what I had read and what friends who have swapped cars have done as well. Another member on here has stated otherwise and I'm just trying to clear the air as his argument seems to make sense.
    Originally posted by Roysneon
    $5 shipped?
    Originally posted by MarkD
    You are a strange dude, I'n not answering any more posts from you.
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    Back of block to bottom (lower) heater core.
    • monkeytaco
      • Jan 2010
      • 882
      ^^^^ This is correct. Otherwise, no heat.
      Looking for a clean e30 shell for a project.
      • samiam3356
        • Jul 2009
        • 1901
        Is the valve on the bottom or top? If bottom then that would be correct as the coolant would go through the black first and then into the HC.
        $5 shipped?
        • 10Toes
          • Jan 2008
          • 61222
          I'v had it hooked up backwards before last december, you get no heat. Also my temp gauge read just past half and when I switched them to the right way it went to just under half.
          • 328ijunkie
            • May 2007
            • 3961
            Im not saying im 100% right but im basing my opposition on the fact the heater valve is in the top Hcore hose and it is designed to stop coolant flowing through the Hcore.
            What im thinking is coolant on a 24v motor flows from the front of the motor to the back then to the Hcore (hot side) and from the overflow tank and the other side of the HC back to the backside of the thermo housing....
            Check Us out on Facebook
            Full Product Line Tuning
            • samiam3356
              • Jul 2009
              • 1901
              Please be more specific. backwards meaning to the bottom or top?
              $5 shipped?
              • monkeytaco
                • Jan 2010
                • 882
                This is for my car's heater hose, the valve is on the bottom, that is what controls coolant flow. Therefore the head is outlet and it runs to the heater core inlet which is bottom.
                I've looked at a couple other versions (88 325i- my brother's car, 87 325e - another friend's car) and its the same way.
                unless the flow is supposed to go into the heater core first, then to the valve, it should go to the bottom. I can't imagine the HC being filled with hot coolant on a summer day, bmw designers wouldn't do that to us would they?
                EDIT:
                This is another diagram for another heater core, which is inlet on top:
                I guess i'm going to look at mine for real and see which is in my car...
                • 328ijunkie
                  • May 2007
                  • 3961
                  Top Pipe Has the Valve on the later model cars
                  • samiam3356
                    • Jul 2009
                    • 1901
                    So it looks like it depends on core you have. And the valve should be getting the hose from thr back of the head. Going to look at mine tonight.
                    $5 shipped?
                    • 328ijunkie
                      • May 2007
                      • 3961
                      No more insight from fellow r3vers?
                      • Dominic49
                        • Feb 2007
                        • 1373
                        back of head goes to valve
                        • 328ijunkie
                          • May 2007
                          • 3961
                          Thats what i thought....
                          • monkeytaco
                            • Jan 2010
                            • 882
                            I checked out my car last night and I have the back of the head to the top (inlet) hose. The valve for mine looks pretty much exactly like yours.
                            I also looked at an 86 325 and it had the valve on the bottom... so check your valve when you hook it up to be sure.
                            • graphikg
                              • Jan 2008
                              • 1614
                              Damn, didnt think it made a difference. I always thought it as "Spider, Top; Back Bottom" A little neumonical method of mine.
